1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2013 Prius (Gen3, Trim 4) head unit dead
Discussion in 'Gen 3 Prius Audio and Electronics' started by johnerh, Nov 29, 2022.
  1. johnerh
    johnerh Junior Member
    45
    Los Angeles
    Well, I finally did it.
    I effed around and found out.
    I had an aftermarket android head unit installed, and I couldn’t wrap my head around why the external mic wasn’t working.
    I found that other android head unit users got the external mic to function by disconnecting the internal mic manually by severing the internal microphone wires.
    I did this, and when I was putting the head unit back in I guess something was disconnected.
    I know for a fact that a 20624 ribbon connector with 28 pins (inside Android head unit - NOT a Toyota cable) is severed, and I am waiting on the delivery for a replacement cable.
    In the meantime, I decided to put The stock head unit back in.
    The problem now is that neither of the stock nor aftermarket head unit will boot up. Completely dead. I don’t know what’s going on.
    Can someone help me out here?
    I know there’s a 15 amp fuse, a 30 amp fuse, and a 10 amp fuse in various locations, but I have no idea if I’m looking in the right spots.
Loading...
