2013 Prius here. Park button not doing what its supposed to do
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chuckiechan, Oct 19, 2020.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    (~ 72k miles)
    Basically when I stop and shut off the car, the doors unlock with a audible “twhack”. Suddenly the sound has changed (much softer) and it’s not operating the door locks properly, but still doing its “Park” job OK.
    In the olden days, I would suggest maybe a $30 relay somewhere. But today?
    Any ideas as to how to fix it?
    Thanks in advance.
  2. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Maybe the 12v battery is getting weak? Have you checked the voltage?
    Possibly one of the locks are not locking. Do all the doors lock/unlock?
    chuckiechan likes this.
  3. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I’ll check that out. Should the battery read 12V with a bolt meter? I’m still on the OEM battery. :eek:.
  4. Mendel Leisk
    42,314
    12.4 minimum if healthy. 12.6+ better.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Depends on age of oem battery.
    pjksr02 likes this.
  6. ChapmanF
    18,998
    Depends a lot on how charged it is. 12.7 or so is around full. Lower, it may still be an ok battery, just not fully charged. If you find it at low 12s or somewhere 11s, see what it reads after some nice overnight R&R on a charger.
    Regarding that all-around thwack when you park ... if it's that way because you really want it that way, good, but if you don't really care, that is an adjustable setting. I have mine set not to do it. I'll just lock or unlock a door when I want to.
    Those lock actuators, one in each door, do wear out. The Toyota replacements are $200-ish if I remember right. Each. Going through the car's life with all four of them set to thwack every single time you park or unpark is kind of a recipe for having them all conk out in rapid succession when the time comes.
  7. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    The battery was 12.38, and the car had sat for three days. I’m planning to get a new bat asap anyway, since 2013 is old for a battery.
    I’ll post back when that is done with the result.
  8. ASRDogman
    8,055
    4,083
    Yep, it's about time for a new one, 7 years, it's had a good life. :)
  9. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    The locks seem to have fixed themselves for now.
    I plan to replace the battery because it’s time. Any tips or cautions? It’s described as “difficult”, but I have replaced my share of batteries.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Source that said so?
  11. Mendel Leisk
    42,314
    Not hard at all.
  12. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    Sacramento weather should be 80-90ish on last 3 weeks. Make sure your gasket no leak.
  13. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    An on-line link said it was fairly difficult, but I rechecked. It’s just a tight fit and heavy, not to mention $200 + bucks.
    I’ll squeeze my gaskets tight when I lift ‘er in!
    Thanks all. I’ll be back if there are problems.
