2013 Prius Hesitation Help ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Markee, Aug 10, 2023.
  1. Markee
    Markee Member
    336
    South Florida Broward County
    #1 Markee, Aug 10, 2023
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Reduce your exhilaration while driving. Some might call that distracted driving!
    Seriously hesitation from a stop on a gen3 can be a severely worn hv battery or a bad head gasket misfiring on the transition from engine stop to running.
    Watch the startups from a traffic light when the hv battery level is really low and compare to stops when the battery has a better charge. Often a really bad hv battery will discharge fast at a light.
    If it is a head gasket and hesitation is often happening at lights, the coolant level is probably going down.
    Other misfires and sensor problems like a bad maf would create codes.
