2013 Prius Hose/Plumbing question
Discussion in 'Gen 3 Prius Technical Discussion' started by Windownerd, Jun 22, 2020.
Tags:
  1. Windownerd
    Windownerd Junior Member
    Maryland
    I was cleaning out my egr and this valve that on the right side that comes out of the engine need a hose. I'm confused on where it leads. Please help asap
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    It's a water inlet or outlet, it's not a valve. If you remove the hose, coolant will come out.
  3. ttou68
    ttou68 Active Member
    351
    211
  4. Mendel Leisk
    42,355
    I see a pushed-back hose clamp, and a coolant hose almost pulled off (or completely pulled off).
    Are you saying you need a replacement hose; the one almost pulled off in the pic is failing? I'm confused.
    BTW, I completely removed this stud (after removing the nut), the one for the lower EGR cooler bracket. The cooler is stable/solid without it, and it makes future removal easier:
  5. Windownerd
    Maryland
    got one swapped. heater core
  6. ttou68
    351
    211
    You're right, it was a different hose I was thinking of... Wasn't thinking.lol
