2013 Prius injector issue
Discussion in 'Gen 3 Prius Main Forum' started by donzoh1, Jan 22, 2019.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    Any ideas on where to get fuel injectors for the 2ZR-FXE motor without killing my budget? I've been quoted 145.00 each! I was thinking maybe get rebuild kits for them. The number 1 injector is apparently not atomizing fuel correctly and has washed the cylinder wall with gasoline so there are now 2 vertical polished areas about where I believe lubrication has been compromised. Also, I am wondering whether the 2ZR-FE motor uses the same injectors.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Let me check my leftover parts. I believe I have a fuel rail that is just taking up space. My 2010 had 213K when it experienced catastrophic disassembly. I’ll let you know in the morning if they are still in my stack of parts
    Raytheeagle and ETC(SS) like this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Also, start an album of the photos that you have questions about. Some of us may have seen what you see before and know how to stop it.
  4. ChapmanF
    19,041
    What I've done in the past is sent them to Rich at cruzinperformance.com, who restores them for $20 each and ships them back to you with test certificates showing the performance of each injector before and after the service.
    He's in Michigan; there could be similar services near you.
    Raytheeagle likes this.
  5. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The most expensive fuel injector for the Prius on rockauto.com is $57.
    Pixel XL ?
    DeezPrius and Raytheeagle like this.
  6. bisco
    52,876
    how many miles on her?
  7. gliderman
    gliderman Active Member
    751
    225
    I dont think the injectors are direct inject into the cylinder.
  8. donzoh1
    450
    153
    Lenexa, KS
    Thanks for the responses! I did find a set of 4 rebuilt injectors on eBay for around 80. Fingers crossed on that!
    mjoo likes this.
