2013 Prius Interior Lights/Charge Ports/Cig all out
Discussion in 'Gen 3 Prius Main Forum' started by Michael Chamoun, Jan 28, 2023.
  1. Michael Chamoun
    Michael Chamoun New Member
    Los Angeles
    Hi all,
    I had to replace my driver side actuator a short bit ago, however the first time I pulled out the interior door frame to access it I accidentally didn't disconnect the bottom light out first. So it forcefully disconnected and the wire is exposed. I successfully replaced the actuator but all my interior lights and cig lighter/charge ports do not work anymore; this includes the interior lights not turning on when they detect my key, as it normally does. I checked all the interior fuses and they are intact. Any advice or help would be much appreciated!
  2. Michael Chamoun
    Los Angeles
    Actually it's just the lights. The cig port works fine.
    52,883
    all i can think is yanking that wire disconnected something further back
    Johnny Cakes likes this.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    If memory serves me correctly, interior lights are not even in the same fuse box as cig/power. I think interior lights are in the engine fuse box, so check there. I think interior lights are on the same fuse as the door lights so blowing that fuse makes sense. Perhaps the cig/power is an unrelated problem.
  5. Mendel Leisk
    42,368
    Maybe it’s just me drawing a blank, but what’s an “actuator”?
  6. Johnny Cakes
    1,065
    789
    Virginia, USA
    Thanks for that edit to your post. Then just change the fuse for the interior lights -- which is in the engine compartment -- and Bob's Your Uncle.
  7. Johnny Cakes
    1,065
    789
    Virginia, USA
    Fancy way of saying power door lock thingie.
  8. ChapmanF
    19,046
    Well, because there are so many actuators for so many things all over the car, it would have been more specific to say door lock thingie.
    But then there aren't so many actuators inside doors, so when the OP said driver's side and pulled out the interior door trim, that kind of narrowed it down.
    (I went to my first movie since lockdown, last month, and noticed the theater seats had bass shakers. Maybe those were added since my last movie, or at least I never noticed them before. Looking them up, I see that some of the fancy ones prefer to be called "linear actuators".)
    #8 ChapmanF, Jan 29, 2023
