2013 Prius IV not normal noise in reverse
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Peppersquat, Jun 20, 2019.
  1. Peppersquat
    Peppersquat Junior Member
    2013 Prius IV ~240,000 miles mint condition
    An alarm-like noise just started when I go in reverse, accompanied by a high pitch noise while driving or coasting at low speeds that doesn't at all appear to be brake related...
    Noise when accelerating appears to be most noticeable around 30-40mph. No noise when stopping or stopped that I can pick up on.
    Nothing dragging or apparently wrong when I inspected the undercarriage. I'm hoping someone smarter than I will be able to identify this probably horrific problem.
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    It sounds like brake pad sensor pin to me, but if you insist it wasn't brake related noise, then sorry, I don't have another answer for you.:p
    Raytheeagle and Peppersquat like this.
  3. Peppersquat
    I definitely don't insist. Logically, I feel like you have to be right. I've just never had pads that make that kind of noise before. It behaving differently going in reverse also threw me.
    I haven't actually taken the brakes apart and inspected them yet (torn tendon in both wrists), so hopefully it really is that simple.
    You gave me exactly what I was hoping for; I just needed someone else's opinion before I pathetically ask my wife to help me with my car.
    Thanks!!
    52,878
    welcome!
    how many miles on her? could just be a pebble, but might be the wear sensor. the pads are always lightly touching the disc
    i cannot discern an alarm, just the high pitch noise
    what's the rumbly/crunchy sound when you stop and start moving in the other direction?
    unless your vpns has gone crazy, but that's only up to 15mph
    #4 bisco, Jun 20, 2019
    Peppersquat likes this.
  5. Peppersquat
    240k miles. Thank you! I honestly doubted brakes could really be the answer because I didn't know that they're always touching, so the fact that it was still making the noise while coasting got me.
    I admit it's the only thing that really makes any sense. I initially thought a caliper was getting stuck *shudder *
    I think what you hear there is just the pavement because it had some gravel dusted around the area. At least I hope to God that wasn't the car.
    #5 Peppersquat, Jun 20, 2019
