2013 Prius losing power on hills
Discussion in 'Gen 3 Prius Main Forum' started by twr200, Mar 28, 2023.
  1. twr200
    twr200 New Member
    Last summer it was a very hot day and I was driving my 2013 Prius up a long winding highway. After a while acceleration slowed and the car was losing power and speed. When it got to 30 mph I pulled over which was scary because there was barely any room on the side of the road. I had the car towed to my destination and then to a mechanic. He checked the codes - all was fine - and suggested I drive off and not worry about it. Well, I drove off, the car works fine, but I do worry about it. I had one sort of similar incident on another long hill, but the car maintained speed at 40 mph and I was able to get over it. All mechanics are stumped because no codes have showed up. I'm afraid to take the car on trips that involve hills now. Previously it made it up the grapevine (going from SF to LA), so I don't know if something has happened which prevents it from going up long hills now.
  2. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    Simple soultion. Your car is most likely overheating. I was in th same boat. The car would drive 1000 km on highway like a piece of cake but would stumble down to 20 km/h on a long hill drive. The car had two main issues. Radiator needed flushing. Plus there was some air in cooling system. Get ur radiator and water pump looked at and u will be good to go
  3. Mendel Leisk
    42,296
    What’s the miles on it? Have you had it since new? If not: what was the miles when you bought it?
  4. ChapmanF
    18,976
    How steep and how long was the hill, and how fast were you driving?
    There might well be no codes, if what was happening was the normal operation of the car. Your gasoline engine can produce 98 HP maximum. If you are driving up a steep enough grade at a speed that requires more than 98 HP, then the battery is chipping in the whole time. But that can only last as long as the amount of charge in the battery.
    If you have something like a ScanGauge or the Torque app connected in your car to show you the actual battery state of charge in percent, and you see it steadily dropping while you're climbing the hill, watch how close it gets to 40%. The magic switch flips just below 40% state of charge: the battery will stop contributing then, and suddenly you find yourself driving a 98 HP car up a steep hill, and your speed is going to drop to whatever a 98 HP car can do there.
    If that's what's happening, and it used to not happen under those same circumstances, it could just be that the battery is older now and its capacity's a bit lower, but not that anything is really wrong besides that.
    If you have something showing you the state of charge, you can sometimes pace yourself, and pick a little lower speed for driving up the hill so the battery will still be at least 40% at the top.
    I nearly had the same experience the time I let my sister drive my Gen 1 up Afton Mountain. She was driving, and I was watching the SoC drop on the ScanGauge, but luckily our exit came just as it was hitting 40%.
    The Gen 1 could do just fine up that same ascent, at the speeds *I* would drive.
  5. KamiKKazi
    KamiKKazi Member
    92
    60
    OC
    How does the battery last driving on the grapevine. I previously had problems with the battery lasting the whole way up the grapevine going south. My battery would go all the way down and my gas engine would get louder ascending the grapevine going south. I made it over but then I replaced the battery with a project lithium and have no problems ascending hills anymore.
  6. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    These tales puzzle me, because my traction battery state-of-charge normally remains constant on long uphills taken at moderate speed. (Of course it initially drops rapidly when I'm forced by a traffic jam to creep up a hill with engine off.) Battery current, as shown by ScanGauge, does not change from what is shown in level stretches. Besides, the battery simply does not contain enough usable energy to be a significant factor on long climbs.
    Specifically how long and how steep, or how high overall, is the "Grapevine" thing Californians like to talk about?
  7. Shahzad Nayyar
    94
    25
    Pakistan
  8. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    70
    Sacramento, CA
    My 2013 Prius is having these issues too, no warning lights or codes. It loses a lot of power under load (failsafe mode) and the engine revs way too much uphill. It has almost 213,000 miles on it. I cleaned the EGR and changed the oil and engine coolant a few months ago. And I am not sure how to safely check the hybrid battery or the inverter due to high voltage.
  9. BiomedO1
    BiomedO1 Senior Member
    4,543
    2,391
    Left Coast
    when was the last time you changed the ATF?
  10. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    Was that ever not true on the same hills? To some degree that's normal behaviour, compared to most other cars.
  11. Brian1954
    Brian1954 Senior Member
    2,667
    1,066
    South Central PA, USA
    Please start a new thread in the Gen 3, Care, Maintenance and Troubleshooting sub-forum. It is much better doing it that way so you do not have information scattered across multiple threads like you are doing. I made the same request on May 8th in another thread that you posted in.
  12. ChapmanF
    18,976
    I took the liberty of bolding your "taken at moderate speed" part, which is key.
    The "Grapevine" thing I don't know about. In Virginia there is a section of expressway that passes through Rockfish Gap, and I know about that. :)
    In ➡this post⬅ a decade ago I told a little story involving Rockfish Gap, my old gen 1, and my sister.
    A couple things to know about gen 1. It had a 70 HP engine (for some reason I wrote 71 in that old post, but no, I have the NCF in front of me right now, it says 70). That's less than the 76 HP they eked out of the same basic engine in gen 2, and it's a lot less than the 98 HP of the larger engine in gen 3.
    That 70 HP from the engine could be electrically boosted up to 97 combined horsepower (under the best RPM conditions), using up to 27 HP from the battery. (The corresponding gen 3 figures are 98 HP from the engine, 134 combined system HP, meaning up to 36 HP from the battery.)
    Whether the battery does or doesn't "contain enough usable energy to be a significant factor on long climbs" depends a little on what you call significant.
    An as-new gen 3 battery, starting at the usual 60% state of charge, could give you the max 36 HP for about 35 seconds before reaching 40% where the boost cuts out—taking only the battery capacity into account (in practice, complications like heat management come in, and I've really never seen anything like max output sustained for that long). An as-new gen 1 battery, which was larger, could give you 27 HP for about 64 seconds in the same conditions.
    As for Rockfish Gap, when I would drive that stretch myself in my gen 1, observing the posted speed limit, the battery never contributed much. That ascent, taken at moderate speed, could be handled within 70 HP from the engine alone.
    But when I let my sister drive, the battery had to contribute. It did not contribute the maximum possible, but only (as I wrote in that old post) "10 to 20 amps or more pretty much the whole way up". Obviously, I was just glancing now and then at the ScanGauge, and don't have a datalog. Those amp figures, at the higher gen-1 battery voltage, come out like "4 to 7 HP or more all the way up". So it takes something like 74 to 80 HP to go up that stretch if you drive like my sister.
    An as-new gen 1 battery starting at 60% can give you 7 HP for about four minutes, or 4 HP for seven minutes—long enough that you definitely can be making some climbs of noticeable length with the battery pitching in the whole way. If the battery does get down to 40% and you lose those extra HP in mid-climb, you'll definitely notice; your speed is going to drop then to whatever the engine output can sustain on its own.
    Now, remember that the gen 1's combined rating of 97 HP is less than gen 3's 98 HP rating for the engine alone. So, a gen 3 could make that same climb and still maybe slightly charge the battery, even with my sister driving.*
    Nevertheless, I'm sure that even for gen 3 there are stretches of road where sustained battery contribution can be needed, when driven hard enough.
    * I'm neglecting whatever the weight difference is between the generations.
    #12 ChapmanF, Jun 26, 2026
  13. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    That's quite an elaborate reply to my 39-month-old post---yet still semi-relevant to Gloria&Suzanne's recent post. Thanks!
    If a hill is too steep, you won't be able to use full-power engine speed without overspeeding (or overpowering) MG1---which the computers wouldn't allow. What was the engine speed with your sister driving?
    I've taken I-64 over Rockfish Gap many times, most recently (and the only time in the Prius) last September en route from Toledo to Richmond. It didn't seem nearly as challenging or memorable as the hills on I-68 in western Maryland, and US40 crossing the southwest corner of Pennsylvania, the way we crossed the mountains in the other direction. I suspect the motors and inverter got hotter then than they'd ever been before, even at my moderate speed (roughly half maximum engine power). Meanwhile, the indicated battery charge didn't budge from its usual six of eight segments. (It does plummet when a traffic jam forces intermittently creeping uphill with engine stopped and air conditioning on.) Descending such hills is interesting, too.
    Getting 7 horsepower to MG2 from the battery at 20 amperes would require it to supply over 261 volts---even after losses. Was Gen 1 battery voltage that much higher?
  14. ChapmanF
    18,976
    Gen 1 had a 38-module battery, so 273.6 volts nominal, easily north of 300 at a high state of charge.
    Gen 1 lacked the boost-converter part of the inverter assembly, first added in gen 2. Gen 2 could use a lower-voltage battery and boost it to 500. Gen 3 can boost it to 650. The gen 1 motors had to run on whatever the battery had on tap.
    The run-an-inverter-off-your-traction-battery crowd had depressingly few product choices able to handle that battery's voltage.
    douglasjre likes this.
  15. Gloria&Suzanne
    70
    Sacramento, CA
    Recently. The mechanic had to do it since the drain and fill plugs were too stuck for me to get off myself.
  16. Gloria&Suzanne
    70
    Sacramento, CA
    Does so more than it used to.
  17. Gloria&Suzanne
    70
    Sacramento, CA
    I did not see my thread messages. I have severe ADHD.
  18. Gloria&Suzanne
    70
    Sacramento, CA
    I looked. Turns out I already DID post that on that specific forum.
  19. Gloria&Suzanne
    70
    Sacramento, CA
    What it can sustain has decreased.
  20. Gloria&Suzanne
    70
    Sacramento, CA
    I was worried about that too, and decided to pull over and shut the car off.
