2013 Prius Misfire codes and o2 sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Radiotech92, Jun 21, 2022.
  1. Radiotech92
    Radiotech92 Junior Member
    Pittsburgh
    2013 Prius 2 85k had egr valve replaced and Both o2 sensors now I have codes p0352 p0354 p0037 p0032 and it misfired so much that the check hybrid pull over when safe came on and the engine shut off. Has anyone else experienced this issue I’m scared it’s the head gasket
  2. JC91006
    16,926
    8,637
    at 85k miles, what made you decide to replace the EGR valve and 2 oxygen sensors?
  3. Radiotech92
    Pittsburgh
    I had a p0032 code and heard a loud pop when the sensor got pulled it had a white spot on it and the egr valve was sticking I had a lot of carbon build up
  4. JC91006
    16,926
    8,637
    Can you describe which sensor gave a "loud pop"? I don't understand how a sensor could create a loud pop sound.
    Are you the original owner of this car? There should not be a significant amount of Carbon buildup on a car with the few miles you have on it. Unless the odometer has been turned back.
    Did you use original Denso parts for your oxygen sensors? If the Air/Fuel sensor is not an original part, it could explain the misfires and poor power issues.
  5. Radiotech92
    Pittsburgh
    I am the third owner of the car got it from Carvana and I remember when I hit the brakes I heard a loud pop and then the check engine light came on and no I didn’t do denso sensors I got it from rock auto
  6. Radiotech92
    Pittsburgh
    Also it was reading originally p0032 for the code
  7. bisco
    52,707
    #7 bisco, Jun 21, 2022
  8. JC91006
    16,926
    8,637
    Well I believe your issues are with spark plug or coils. Which is rare to have with a car with so few miles. But I would check the spark plugs and coils, if they are bad, replace them. Then if things are still not right, then I would address the non original air/fuel sensor you put in from Rock Auto
