2013 Prius PCV Valve part advise.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, May 17, 2020.
  1. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    I want to replace my 2013 Prius two PCV Valve. My local AUTOZONE has OEM part listed as fitted 2013 Prius and Part # PCV1114DL
    When i pick it up, it's not fit the socket 22mm as most tutorial video as told.
    Can one tell what exactly part # or equivalent part ?
  2. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I recently removed my PCV valve on my 2012, and it surely did take a 22mm deep socket. Close enough to 7/8" in case you don't have a 22mm deep. An open end wrench will work too. Even an adjustable wrench will. The torque required is not much, despite the size of the socket needed. Something like 29 Nm - but look it up yourself to check.
    So I think it's a safe bet that when you get to the PCV on your car you'll find it as I describe here (matching what the tutorials probably say).
    Not sure what part you got from Autozone. It might be that the threads will fit, so it truly is a valid replacement, but the socket size may be different. I've had that exact situation in different applications several times over the years when using aftermarket parts.
    BTW, you're asking about a 2013, but your profile says you have a 2012. Should be the same answer for both.
  3. Tekken
    Tekken Member
    260
    77
    Thanks 2012 Prius v wagon 3, AutoZone aftermarket parts.# maybe different size. As long as it fit in and using different socket or wrench not affect the preferment.
    I wait if anyone can give me the Oem part or order direct from toyota dealer.
    My vehicle is 2013 prius.. don't how it showed up as 2012 on my profile
  4. Tekken
    Tekken Member
    260
    77
    I found one from O'reilly Auto Parts. it came with sealant and it fit in Socket 22MM. part #n28-0230
    PatrickBrian likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
  6. Mendel Leisk
    42,354
    I would stick with the OEM Toyota part. They might fit physically, but have different internals, performance.
    Safest to just pick it up from a dealership parts department: tell them you need the pcv valve for a such-and-such, and model year. Then you don't even need to know the part number; that's their job.
    It's under $10 for the OEM.
    I've had ours out a couple of times, shoot carb cleaner through it, apply a little Permatex 243 thread lock to the threads (mostly for cosmetic reasons, to avoid a slight oil-bloom), reinstall.
    James Finch and PatrickBrian like this.
  7. Tekken
    Tekken Member
    260
    77
    True.. local toyota part need to 10 business to ship over. Let me try this aftermarket for $6.99 and has lifetime qaurantee by O'reilly part
    BTW, Cant believe that I clear up my ERG pipe and ERG cooler 2 week ago, Now the ERG pipe full off moister and light oil inside.
    RMB and Mendel Leisk like this.
  8. Mendel Leisk
    42,354
    How many miles? Hang onto the old one for sure.
  9. Tekken
    Tekken Member
    260
    77
    97600k.. I'm did my 100k maintenance. ERG cooler was done 2 weeks ago. All the Manifold, oil, transmission fuild, engine and inverter cooler changed. Spark plus done etc...
  10. Tekken
    Tekken Member
    260
    77
    Changing my PCV valve now is last item on 100k maintenance.
    It piss me that everytime when going up ramp on Highway/Freeway. The acceleration extremly poor, approx 20 sec to reach 50mile/hr. I feel the pedal's vibration on everytime It reach PWD bar. Driving on ECO bar, no vibration.
  11. PatrickBrian
    PatrickBrian Member
    64
    Pittsburgh
    2014 Prius v wagon
    Wonder what ever happened with this, knowing what we know now.
  12. James Finch
    James Finch Junior Member
    69
    Whitehall, Mi
    How'd the PCV Valve change do to effect performance? I found sludge in my EGR and Intake EGR circuit and am like bummed I definitely have to now clean the EGR Valve and Cooler since that sludge crap isn't going to turn to powder like I would have prefered to find like in the donor intake and egr circuit parts.
  13. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    I changed mine on my oil burner at like 180k. Didn't make a difference. But I have had good luck just ultrasonic cleaning them or boiling them and putting them back in. My Sequoia was sucking oil through the pcv valve when i first got it. Just cleaned it and it went back to normal. It was just stuck in one position though. The one on the prius was just a little sludgy.
