2013 Prius scary noise at Cold start.
Discussion in 'Gen 3 Prius Technical Discussion' started by Msuddin, Apr 21, 2017.
  1. opticell
    opticell Junior Member
    61
    Ogden, Utah
    Msuddin, wow hope you solved this issue. I found the problem that was causing mine and was an easy fix. I first heard this scary issue, causing thoughts of hurry and sell this Prius, a few years ago on my sisters 2012 Prius, then it happened to me a few months ago on my 2010. I was certain the engine or transmission was about to go out or fail at the least opportune time, and couldn't trust it for long trips. On mine I determined the loud metal to metal clacking sound came from the area just beyond the engine. Today I spoke with a friend at Toyota, he's the service manager, and was told the sound is the Damper clutch doing its job during abnormal conditions. ok enough talk.
    My problem: Every cold start, loud noises came from the engine transmission area for 10-20 seconds, though I would shut off the engine and try again until it stopped. The engine was missing on one or two cylinders for a short time after start. This caused erratic behavior on the Damper clutch plate and flywheel assembly. The result is the clutch engaging and disengaging rapidly until all cylinders are firing. This problem has no error codes, nothing but the life stopping loud noises and violent engine rocking coming from the engine compartment.
    My solution: When I discovered the engine was the cause, and no malfunction of the transmission, I suspected the spark plugs. In my case, it had been over 150,000 miles since my last spark plug change. I have replaced all four spark plugs, and since have driven 20 cold starts, 45 minute commutes, with no sign of this knocking/loud banging. For now this is solved, I'm greatly relieved, and once again trust my Prius for long trips. Spark plugs had small amount of carbon build up on 2 of 4 plugs.
    telmo744 likes this.
  2. JRC1981
    JRC1981 New Member
    How has this turned out for everyone?
    I have the same issue.
  3. Mendel Leisk
    42,347
    What’s the miles, and do you plug-in a lot, or it’s mostly driven just like the non plug-in version? Has the EGR (Exhaust Gas Recirculation) system and intake manifold been cleaned, and if so when?
  4. JRC1981
    JRC1981 New Member
    The mileage is 210K. Never really plug it in. EGR or intake manifold has not been cleaned.
  5. Mendel Leisk
    42,347
    It’s very likely head gasket. Coolant level stable in engine reservoir (by right fender)?
