2013 Prius sudden oil consumption, PCV valve ok
Discussion in 'Gen 3 Prius Technical Discussion' started by romanlutsk, May 3, 2020.
  1. romanlutsk
    romanlutsk Junior Member
    73
    Cupertino, CA
    2002 Prius
    My dad has a 2013 Prius with 204 K miles and has noticed a sudden excessive oil consumption (over 1 qt per 1000 miles). However, it only seems to occur at highway speeds. City driving (when the engine is not strained) doesn't seem to cause any oil consumption.
    Exhaust pipe is clean and there is no smoke from the exhaust at start-up.
    He uses 0w-20 and changes it every 5000 miles religiously.
    Cleaning PCV valve didn't help. Also, there is an excessive air pressure in the crank case (you can feel quite a bit of pressure when you unscrew the oil cap while the engine is running)
    A few questions:
    1) Is it 100% worn-out rings letting too much blow-by into the crank case or there is some other reason? (Perhaps there is some other crank-case ventilation vent that's blocked?)
    2) Would using heavier oil (say 5w-30) help reduce the oil consumption without (much) irreversible negative effects?
    3) Is is possible that the oil/carbon deposits prevent the piston rings from making a good contact with the cylinder? If so, what are some effective methods of removing the deposits? (I've head of some people introducing water into the air intake in hope that the resulting steam would clean off the deposits, but I'm not sure how it's supposed to do that).
    Any comments, ideas, suggestions would be highly appreciated.
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Has the egr circuit even been cleaned? Along with the intake manifold?
    Cleaning the pipe is only a small portion of it. The EGR Cooler gets clogged,
    and the egr valve also. That's why you need to clean the how circuit, at the same time.
    And you can clean the intake where the valves and injectors are, when the intake manifold is off.
    They will probably be very oily
    And possibly a new pcv valve. Cleaning it might help, but since they are only $8-10,
    it's worth replacing.
    Ring could be a possibility, but it's more likely the valve guide seals.
    Oil will build up in the intake manifold. And oil catch can will help control that.
    How fast are you driving? 70+ mph and up sucks oil.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Our 2010 would consume a quart of oil every 4-5k miles:cool:.
    More when I upped the speed it would go;).
    Has the car ever been run low on oil before:whistle:?
    If allowed to, this is the cause usually for the rate of oil consumption your father is experiencing:(.
    Cleaning the egr circuit stem to stern, using oil flush products (like BG Products EPR) and clubbing up (I went with 0w-40 at the end) is what I did. Some those can work:).
    Good luck and keep us posted(y).
  4. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I'd focus on the crankcase pressure. The oil consumption is a symptom of that. So get the pressure down. PCV would be the first place to look. Maybe replace vs. clean. Confirm the full PCV system is clear and working - so the tubing, etc., not just the valve itself.
    Jim Swart and Mendel Leisk like this.
  5. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Thanks for all the points. I didn't know dirty EGR system could have any effect on the oil consumption. Would someone elaborate?
    He's driving highway speeds - 70-75 mph. He's been changing the oil every 5K miles since he got the car (I bought it at the copart in Sacramento in 2017 and it had 191 K miles at that time already. I'm not sure what the oil change interval was, but I assume it was a rental/fleet/delivery vehicle with mostly highway driving).
    Yes, he made sure the PCV tube that connects the valve to the intake manifold is clean and checked that the valve is working properly. Are there any other parts/points to check?
    It's not easy to get your hands on a new PCV valve for the Prius where he is. How is a new valve different from a thoroughly cleaned old one?
    Thanks again!
    #5 romanlutsk, May 3, 2020
  6. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    So 13 k miles in less than 3 years;).
    I'd just monitor the dip stick frequently and add oil as necessary as there appears to be downtime as the miles aren't piling on from his ownership:).
    Situation can be managed with data(y).
  7. Mendel Leisk
    42,377
    Spring might weaken a bit over time. Wouldn't that improve flow though? Yeah I've hit ours with carb cleaner a couple of times now, basically the two times I had the intake manifold off. I used a little Permatex Thread Lock 243 on the threads. Mainly as a make-do thread sealer. It's cosmetic I think, just to avoid a slight oil bloom around it.
    Here's a little Repair Manual info, testing it. Still, if you've shot carb or brake cleaner through it, and it's rattling freely, would think it's good.
  8. Robehne
    Robehne Junior Member
    Columbia, MO
  9. Robehne
    Columbia, MO
    My 2010 Prius burns a lot of oil. Burning oil cloggs the egr cooler and the air intake manifold. Both can be removed and cleaned. I put an oil catch can on mine to help reduce the build up. Every 10,000 miles, I clean the intake manifold. Every 100,000 I clean the egr cooler. My Prius burns 1qt of oil every 600 miles. More on the highway. You don’t see the smoke because it’s recirculated and burned. I assume it’s has bad rings, but I’ve been running like this for 150,000 miles. NutzAboutBolts has all these how to videos on YouTube to keep your oil guzzling prius going. Good luck. I clean the egr cooler and air intake at the car wash. Just remove the egr valve from the cooler and blast out the cooler at the car wash. Same for air intake, remove sensor and blast it clean at car wash.
  10. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    What weight oil do you use? I have 10 w 40.... I use 1 quart every 6000 and I have 250,000
  11. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    What do you think about using plumber's PTFE tape rather than any kind of chemical sealant?
  12. Mendel Leisk
    42,377
    That's not a bad idea. I used permatex 243 (medium strength thread-lock, removable, oil tolerant) with a recent oil catch can install and after cleaning the PCV valve. The valve is still in, and holding tight, no oil bloom.
    But I took the OCC apart just a little later, and opted to go with plumbers tape. First off, cleaning off off the Permatex was a pain. I ended up chasing the threads with a knife tip, round and round, it's the only way.
    And the permatex was problematic with oil catch can, because many of the fittings are 90 degree elbows. You want them angled a certain way, and if they're tight long before you get to the preferred orientation, it can be very tough, turning them through another revolution, with the NPT thread, which is conical, progressively tightening.
    The plumber's tape OTOH, gives the threads a compressible buffer, so they tighten gradually. And it seems to seal well. Only thing, I'm not sure if it can take the temperature, screwed into the engine block.
    Hmm, starting to argue with myself here. Maybe permatex for the valve, plumbers tape for OCC's, lol. I believe when you buy the Toyota PCV valve it comes precoated with a thread sealant.
    Bottom line: you could install the pcv valve with clean (albeit oily) threads, and the only downside is a slight oil bloom, in my experience..
    2012 Prius v wagon 3 likes this.
  13. 2012 Prius v wagon 3
    281
    278
    In both cases there (OCC and PCV valve), there is very little gas pressure and no concern for things backing out, but you do need to keep a tight seal to make sure a vacuum leak does not cause running problems.
    The Teflon tape should be OK up to about 500*F, which should be fine for just about anything other than exhaust. So it should be fine. I used it on my OCC, and I think I did also on the PCV valve. Service manual spec on the PCV valve is to use some special liquid sealant, which I could tell was on there when I removed mine. It was a clear brittle sealing liquid.
    BTW for actual plumbing, where high temperature is not a concern, you might consider Rectorseal No. 5 instead of Teflon tape. In my experience as a homeowner, it never fails, vs. the Teflon tape sometimes will leak a little. Most professional plumbers prefer the Rectorseal as well. The guidance is to use the tape if you need it to be easily removable and not messy, but if it's a one and done install and you can be careful to avoid a little mess, the Rectorseal is the way to go. But the temp spec on that is not as good as the tape, since it's a liquid/paste.
  14. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Get a New Engine........
  15. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    I’m using BG EPR/MOA preventatively to stay ahead of this issue. There is a post on it being used to restore consumption to more acceptable values.
    She Likes to Drink-Should I Get Rid of Her? | Page 2 | PriusChat
    There’s also some discussion on the true source of oil consumption being either stuck rings or worn valve guide seals or both. Toyota did update the pistons and rings at the end of this generation Prius and the Corollas with similar 1.8L engines were known to get stuck rings.
    valve stem seal DIY | Page 3 | PriusChat
    Raytheeagle likes this.
  16. Mendel Leisk
    42,377
    My "theory": the stuck piston rings is caused by a combo of:
    1. The lightweight, low tensiion piston rings, spec'd by Toyota to get slightly higher mpg, model years 2010 to partway thru 2014. At some point in 2014 they revised the pistons/rings, and the revised parts are spec'd as the cure, in the TSB on excessive oil consumption.
    2. Clogging EGR, which will raise combustion chamber temps, which maybe accelerates ring clog up. Third gen was the first to have this style of EGR, and EGR revisions in fourth gen all point to tacit adminsion that the earlier version was not up to the task. 4th gen press releases even mention EGR revision, which seems esoteric stuff for sales brochure material.
  17. ASRDogman
    8,070
    4,092
    The one person who pulled the pistons showed a photos of the rings. He said the rings were not sticking.
    The photo shows them looking like they are new.
    If rings were sticking, or weak, you'd lose compression and notice a lack of power.
    It's the valve guide seals....
    Cosmo Tigato likes this.
  18. Mendel Leisk
    42,377
    Maybe both?
  19. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    I'd go with a piston soak and engine flush, followed by a full egr system clean also switch up to maybe 5w/30 oil, done this on both my 2010 and 2012 prius and they have 230,000 and 198,000 miles on them and both do not burn more than a 1/2 a quart every 10,000 miles (UK recommended oil change interval).
    Ive used liquid Molly engine flush for the piston soak, left it soaking as long as possible (I actually when on holiday) then turned engine over (WITHOUT THE PLUGS IN VERY VERY IMPORTANT to remove any excess chemical from combustion chamber and avoid hydro locking engine) used rest of chemical to do a normal engine flush (you will need to change oil and filter anyway after doing piston soak as chemical leaks past rings into oil) and hopefully this will free of stuck rings.
    I now do a engine flush every 3rd oil change (6 months for me) as the chemical is ment to clean around the rings (the piston soak was a one time get it clean first thing) and so far no oil burning issues on either cars.
    Also oil is fully synthetic cheapo brand.
    RMB, Raytheeagle and Mendel Leisk like this.
  20. taxidriver50005
    204
    170
    GB
    Excel
    Thought it was oil rings that clogged and stuck
