2013 Prius sudden oil consumption, PCV valve ok
Discussion in 'Gen 3 Prius Technical Discussion' started by romanlutsk, May 3, 2020.
  1. ASRDogman
    ASRDogman Senior Member
    7,535
    3,892
    282,xxx plus miles on mine! IT IS A GREAT CARE!!!
    About a quart every 5,000 miles, original head gasket....
    No one is forcing to keep the car.... I'll take it if you don't want it.
  2. johnHRP
    johnHRP Active Member
    643
    185
    KA, DE
    Excel
    No, those products cause more harm than good. It is very thick and often ruin seals over long periods. The problem is usually the clogged piston oil ring. We can reduce it slowly by using high detergent 0w-20 engine oil like Mobil1 ESP or extended performance or any DexosD, vw 508/509 certified oil.
  3. Tim Jones
    Tim Jones Senior Member
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    I take very good care of my vehicles. Had a chevy astro with over 350,00, aerostar 269,000, plus toyota with 437,000 and 320,000 and no major repairs....
    Then there was the 2013 prius v........................
    Inveter stranded 1100 miles from home
    Head Gasket
    2 Water Pumps
    Traction Battery
    Master Cylinder
    Transmission................
    A really crappy car............................. all gas savings lost and a few real hastles. with the car in toy for over a month for warrenty repairs
  4. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Tim,
    I luckily skipped the Gen 3 Prius. I had a 2004 Prius for 12 years and 288k miles (replaced the traction battery at 195k miles - less than 2 cents/mile) with very few problems - a great car. My experience with the Gen 4 Prii although not as long (my 2016 was killed by a kamikaze deer) and my 2020 AWDe (only 2 years old) have both been great cars so far.
    JeffD
    Tim Jones likes this.
  5. ASRDogman
    7,535
    3,892
    No problems with my Pruis.
    No inverter problems, no head gasket problems.
    But, I did the services. Cleaned the egr system a few times, changed fluids, spark plugs, filters....
    Used the Prolong system on the hybrid battery.
    SUPER GREAT CAR!
    Put a few hundred thousand miles on a 76 Corona wagon, 2 78 Corolla's, a few hundred thousand
    miles on them.
  6. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    And how many miles on it. You will be singing a different tune sooner than later.
    SUPER JUNK CAR!
  7. ASRDogman
    7,535
    3,892
    282,225 miles, today.
    PRIUS IS A GREAT CAR! Everyone should own one!
    "IF" there is a problem, I'll fix it. No labor cost.
    And STILL a lot less than $30,000 for a new car, if you can find one! (y):whistle::whistle::whistle::whistle:
    mikey_t likes this.
  8. johnHRP
    643
    185
    KA, DE
    Excel
    We talk about statistics number. The 2010-2011 is the worst in term of oil consumption. The 2015 model is the best and very few has problems. There are many has no issue even beyond 300k miles but many also have issues before reaching 200k miles. I noticed fewer problems in europe because better standard engine oil sold there, super 95/ AKI 89 gasoline, majority E5 instead of E10. But also, people are more aware about maintenance better.
  9. Mendel Leisk
    41,295
    Why would the 2012 through 2014 be any better? The oil ring revision happened partway through model year 2014, and AFAIK that's the only change.
  10. johnHRP
    643
    185
    KA, DE
    Excel
    I understand it completely, i only use statistics from carcomplaint.com and what my mechanics said. Somehow the 2010-2011 has much higher failure rate. But it is indeed true, the 2015 model really have much less issue after the piston amd rings update.
  11. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    "Somehow" because the 2010-2011s sold in larger numbers AND are older AND have more mileage, on average. Did your statistical analysis account for all those factors?
    ASRDogman likes this.
  12. johnHRP
    643
    185
    KA, DE
    Excel
    Yes, it is already counted. If the 2013 has problems it will show up with similar number after almost 10 years now. The problems in 2010-2011 showed up within the first 6 years but 2012-2015 still have much lesser issue after 6 years.
    2010 Toyota Prius | CarComplaints.com
    One of the reason, many 2010-2011 owners has no knowledge how important using full synthetic 0w-20 is, and often they went to quick lube or walmart $25 oil change. And remember, not all Toyota dealership use Toyota engine oil, sometimes whatever the cheapest 0w-20 they can get. There are some 2010-2011 owners with 200k miles or more but still have less than 1L/10k miles oil consumption. By the year 2013, almost all oil require GF5 standardisation
    #52 johnHRP, Oct 16, 2022
  13. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    Are you familiar with the idea that the reliability of any particular car year/model is a bell curve? Perhaps you got one at the bottom of the curve in terms of it being a statistical outlier in having things go bad. Every single car model year has better and worse individual vehicles (which can be exacerbated by how the car is cared for). I'd be mad too if I got a lemon like yours.
    And I'm not denying that the 2010 Prius has a poorly designed EGR and bad piston valves. That is well known. I am in denial that the rest of the car sucks.
    Maybe it is because my 2010 only has 115,000 miles on it, but knock on wood it has been rock solid reliable so far. Not a single issue ever with anything. I'll be willing to eat my words if my fortune changes by the time I get to 200,000 miles.
    What mileages did you have those various problems at?
  14. johnHRP
    643
    185
    KA, DE
    Excel
    Most people who have the problems are either cheap on maintenance or get it as a used car with no maintenance history. Even the worst 2010 models often are still running well beyond 200k miles if the owners keep it in shape from new. We got tons of bad reports on the 2010-2011 production because most people who owned them are often ignorant about the maintenance and how important using a full synthetic oil with 10k miles intervals is.
    Once oil consumption started, EGR needs to be cleaned more often to reduce pinging, head gasket failure, and dead catalytic converter. But it is indeed true, very often 2010-2011 owners have either or all of these problems.
