2013 Prius Three Daytime Running Lights
Discussion in 'Gen 3 Prius Main Forum' started by OrangeCountyPrius21, Apr 22, 2013.
  1. OrangeCountyPrius21
    OrangeCountyPrius21 New Member
    I just bought a new 2013 Prius Three. I see the "DRL" option on the light switch for daytime running lights but they don't seem to work. Is this not a stock option for the Prius Three?
  2. rekniht01
    rekniht01 Junior Member
    Knoxville, Tennessee
    The DRL are the small rectangular lights in the bumper. If they are not on when the switch is on AND the car is in READY, than something is wrong.
  3. matt b.
    matt b. Member
    251
    60
    L.A.
  4. DuaneHebert
    DuaneHebert Junior Member
    26
    Montreal
    On my 2012 they don't come on until the parking brake is released.
    whitmanrf and Sfcyclist like this.
  5. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Daune is right, they don't turn on till parking brake is released.
  6. Sfcyclist
    1,621
    376
    SF, CA
    Also, in "Setup", I believe you can also turn them "off". I haven't played with it but ran across that when I was customizing my settings. I assume if you set it to off, the won't turn on regardless?
  7. BZzap!
    BZzap! Senior Member
    1,607
    878
    Yes, you can toggle the off/on in your set up menu under "Vehicle". Also, the DLR's do not stay on when headlights are on.
  8. SalixIncendium
    SalixIncendium Tree Hugging Environmentalist Wacko
    155
    68
    Dayton, OH
    On the DRLs, it looks like there are 6 LEDs on either side, but on mine, only the top 4 on each side are lit. I never really paid them much attention until today and it seems it would be a bit of a coincidence if the bottom two on both sides burned out. Anyone else have more than 4 on each?
  9. fuzzy1
    10,706
    It has 6 lenses -- more like 5 and a half-- but only 4 LEDs. When off, the LEDs are the yellowish patches behind the lenses, present only at the top 4 spaces. The lower clear spaces are just decorative.
    SalixIncendium likes this.
  10. MansTer420
    MansTer420 Junior Member
    119
    huh?! My 2013 Pii 's DRL comes on even b4 the brake gets released...
    SAMSUNG-SGH-I317 ? 2
  11. Sfcyclist
    1,621
    376
    SF, CA
    Only 4 LED in there but has lens for 6. Cost reduction?
    In regards to the customized setting, when you turn it off, it overrides the switch. Once set it off, it will not turn off when the switch is set to DRL.
  12. fuzzy1
    10,706
    Lens for 5 and a half, not 6. I strongly suspect they are driven in pairs, not singly, so it never had 6 LEDs.
    So it is cosmetic.
  13. Sfcyclist
    1,621
    376
    SF, CA
    You're right 5.5.
    Anyone open it up? I want the light to be in a vertical row vs. 2x2.
  14. Keith Elkin
    Keith Elkin Member
    116
    32
    Are the DRL supposed to come on automatically during the day even when the headlights are switched off? (I thought they were supposed to, but mine don't.. even though my settings have DRL turned on)
  15. rekniht01
    No, you have to physically turn the knob to DRL for them to be on.
  16. Sfcyclist
    1,621
    376
    SF, CA
    Auto ON is only on Trim 4 and 5, Persona along with all other trims have auto off.
  17. fuzzy1
    10,706
    Without knowing the actual details about how the LEDs are electrically driven, I'm going to guess that there is a reasonable chance (significantly greater than 0%, but less than 50%) that you could modify it by disabling half the lights, leaving a vertical pair lit. But there would be a similar chance of getting a horizontal pair instead, and a significant remaining probability of getting none of the above. And I won't pay for the repairs if you don't get what you want.
    Getting a vertical row of 3 lamps will require both electrical and mechanical modifications, with a 98% chance that the mechanical changes not be within my ordinary skills. :).
    DRL is supposed to be inherently auto-on, as in always on when moving unless some other headlights are on.
    My 2012 Three works that way, I don't yet fully understand the changes made for 2013. What is different about this system, compared to Canada and to some other US systems, is that the driver has a configurable choice of DRL or not.
  18. Fong
    Fong Member
    85
    32
    Arizona
    How to keep DRL's running even when you turn on your headlights. DRL's On all time.jpg fuse.jpg
    Tap the red wire and run to the fuse. See images.
    vthreee, yoyoman and Daddyjeph like this.
  19. Yakuzahi
    Yakuzahi Junior Member
    85
    Long Island NY
    That really upset me when I figured it out ONLY after I bought the car.
  20. Sfcyclist
    1,621
    376
    SF, CA
    no biggie.. worse if no auto on/off..
    on persona, there was a misprint that it had power seats...
