2013 Prius Three Daytime Running Lights
Discussion in 'Gen 3 Prius Main Forum' started by OrangeCountyPrius21, Apr 22, 2013.
  1. Jeff1216
    Jeff1216 Junior Member
    Santa Monica
    Pm?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Private message, or in this forum a conversation. ;)
    sfv41901 likes this.
  3. jason petter
    jason petter Junior Member
    how can i chat pm? because i really want to know ,How to keep DRL's running even when you turn on your headlights.
  4. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Some make a video on how to do it?
    jason petter likes this.
  5. Joewin M
    Joewin M New Member
    Wellington New Zealand
    hi there!!! Mine is prius 2013 1.8 S type japan.. It has no DRL built in? How can I install? I have no idea. Thanks mates Joe
  6. fuzzy1
    10,706
    I'm going to guess that you could buy U.S.-market turn signal housing with the LED DRLs, to replace your existing front turn signals. Then just connect the DRL wires to a switched 12V in whatever manner you please and can manage.
    I have a second-hand set (not for sale), meant to replace an original with broken lens, but just haven't gotten around to doing the swap yet. Access doesn't look easy, and the DRL wire connectors are missing and not yet replaced. The DRLs are rated as 7.2 watts per side, or just over a half amp each. Tie them directly to 12V and they light up just fine, no external drivers needed, that is all internal.
    The turn signals are wired separately. If the overall design is the same, you should be able to just twist the lamp holders out of your signal housings, and twist them into the U.S.-market housing.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
