2013 Prius three. Screen intermittent, with lines etc
Discussion in 'Gen 3 Prius Main Forum' started by Jondaniels, Nov 9, 2019.
  1. Jondaniels
    Jondaniels Junior Member
    Fl
    Screen sometimes works normally, sometimes shows up like this. Been happening more frequently. (Different colors in the photos from playing with the brightness and contrast a little)
    Is this something that can be fixed or do I need a new MFD?
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Looks like the contacts on the digitizer cable have a moisture and/or corrosion problem. You might have to send it in to a repair service or exchange service.
    Jondaniels likes this.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,060
    789
    Virginia, USA
    I had a not dissimilar issue with my Prius, although it was the JBL unit. Dealer will not replace just the screen, rather replaces whole new unit. At least for the JBL, it was about $2,000. I found a business in California (I think) that will replace just the screen for a couple hundred, but you obviously have to be able to remove the unit (or have the dealer do that) and send it to them.
    I actually never followed through with the repair because my Prius got rear-ended at a red light and totaled, so I bought a whole new Prius. The bright side was that it got totaled before I fixed the screen!
    Bay Stater and bisco like this.
  4. Jondaniels
    Fl
    I’m not sure, but i think it started when I came back from a vacation and the car was sitting in a garage for 3 weeks.
    It normally happens when it starts up, then goes away after I drive a bit.. lately it’s been staying longer. Also seems to happen in the daytime while it’s hot more often (I live in s fla and it’s still 85+ everyday)
    Figured I’d add some more info. Does that still sound like a moisture/corrosion issue?
  5. Jondaniels
    Fl
    Also noticed it’s much worse on Daymode. Night mode seems to look fairly decent & doesn’t have any lines going through it
  6. BZzap!
    1,607
    878
    Sure sounds like moisture related problem. The high humidity in FL. probably isn’t helping matters any. When you use the A/C, it dehumidifies the air in the car. This might explain the improvement in the screen resolution after you’ve driven it for a while.
  7. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Perhaps a bad ground? If you can remove the display system, check and clean all the connections. Good luck
