2013 Prius Three - shaking at startup, but not every time
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sani, Mar 17, 2019.
  1. Sani
    Sani Junior Member
    Kansas City Metro, KS
    Good afternoon. I have a 2013 Prius Three I purchased used in October, 2016. It had 91,646 miles when I purchased it, and it's now approaching 125,000 miles. I have full maintenance records from pre-purchase via the CarFax report, and it was maintained at the dealership approximately every 5,000 miles.
    I've noticed on a few occasions this winter that the engine will shudder and vibrate rather dramatically at start-up. It did this once when I came out after work on a cold day. I shut it off and back on, and it ran normally after that. It did the same thing a few weeks later when starting it up at home. Again, turning it off and on resolved the issue.
    I have noticed since these happened that the engine seems to vibrate or shudder for just a moment when it shuts off at a stop. It almost makes me think one of the engine mounts has gone bad, but it seems very intermittent, when a broken mount would be a problem constantly. I do not have any dash lights or codes. As far as I am able to tell, it is not leaking or consuming oil.
    When I took it to the dealership for the recall at the end of January, the service tech mentioned that I should get the spark plugs replaced soon, as they can "cause trouble" if they aren't replaced. He didn't elaborate on what that meant.
    Seeing the threads about head gasket problems has made me very nervous, but my symptoms don't match exactly. My vehicle was built after the redesigned intake manifold was rolled out. Does anyone have suggestions as to what I should be looking out for, or maintenance I should be doing? I appreciate your time.
    52,822
    time to clean the egr circuit. see the youtube directions from nutzaboutbolts
    NutzAboutBolts and Raytheeagle like this.
  3. Mendel Leisk
    42,323
    Start by checking the EGR pipe, it's the easiest to get to by far. It's condition will give you an idea what the rest is like. @NutzAboutBolts video number 16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    How the level in the engine coolant reservoir?
    A "leak-down" test would be good, to test the head gasket condition. The dealership or an independent could do this.
    NutzAboutBolts likes this.
  4. Sani
    Sani Junior Member
    Thanks. I’ll check out the EGR.
    The coolant level is good. The dealership changed the engine and inverter coolant before I bought the car at 91,000 miles. That does remind me, though — when it was warmer, I did notice the coolant would hiss after the vehicle was parked and turned off, and there are some small spots of dried coolant on top of the reservoir closest to the right fender. I’m not sure if that’s related in any way or anything to worry about.
  5. Mendel Leisk
    42,323
    First time I read that I thought wow, what a great dealership, lol.
    RMB and Sani like this.
  6. Inspector858
    Inspector858 New Member
    San Diego
    Engine replaced before you bought it? Seems like a HG issue before you even knew about it and now the save issue with another engine? Wow Toyota has really outdone itself now. I just saw a 2019 Prius YouTube video experiencing this. Money maker for Toyota that’s for sure.
  7. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    "The dealership changed the engine [coolant] and inverter coolant...."
  8. Sani
    Sani Junior Member
    Unfortunately, my Prius was totaled in July by a girl in a Mercedes looking down at her phone, so I never got to the root of this issue. A flight of angels sing thee to thy rest...
    SFO, bisco and Mendel Leisk like this.
  9. Mendel Leisk
    42,323
    That's a cool thought. :)
  10. JohnnyJavelin
    JohnnyJavelin Junior Member
    A coworker had is 2012 Prius headgasket changed by Frontier Toyota under the California PZEV emissions wtty provision
    ! But they wouldn't change his piston rings for free, so he is burning a lot of oil. But no coolant..
  11. bisco
    52,822
    how many miles?
  12. JohnnyJavelin
    Under 150K as per Cal regs for PZEV emissions wtty
  13. bisco
    52,822
    That’s great, and first I recall.
    There are threads here on helping with oil burning, as well as cleaning the egr
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    We ask for miles logged because it gives us a better approach to help. But if you want miles to remain anonymous under 150k, alrighty then.
  15. JohnnyJavelin
    its not my car. I only know what I was told.
