2013 Prius two $10500 90k miles
Discussion in 'Gen 3 Prius Main Forum' started by papshadalac, Mar 7, 2017.
  1. papshadalac
    papshadalac New Member
    Michigan
    I'm looking to purchase a 2013 Prius two with 90k miles. They are asking $10500. Decent carfax. Dealer maintained until around 30k miles. No recorded accidents. Is there anything obvious Prius specific to look for? I've been reading some threads on the 2010's with headgasket issues that makes me nervous. Otherwise I think it's a good deal. I've owned a Prius C in the past. So I'm kind of familiar with the way the car should act. Thanks for any info.
  2. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I'd say that is a little high. I can get a 2013 II for $9,999 with 43K miles on the clock.
    $11,999 for a 2013 II with 34.4K on the clock.
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Man over here in Socal it's2-3k above that on average.
  4. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Those are prices are out of Fl.
  5. bisco
    52,792
    welcome!
    if that's the best deal you can find, go for it. all the best!(y)
  6. papshadalac
    Michigan
    So the headgasket issue.... usually caused by failing water pumps correct? As far as the inverter is concerned, the software update "fixed" the issue or should I even worry about it? Thanks for the help.
