2013 Prius Two - Hidden Menu Different
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WastedTheLight, Oct 24, 2016.
  1. WastedTheLight
    WastedTheLight Junior Member
    16
    Bloomfield Hills, Mi
    Good afternoon!
    I installed a backup camera on my car and it works great. I wanted to get inside the hidden menu to see what options may be there but see that my menu is different than the examples in the videos.
    Please see attached photo. Holding Setup and then turning the lights on and off a few times brings me here, to the red bar screen. Hitting "next" takes me to the green bar screen. I'm not getting any other options. The camera button on the top right doesn't work either. 20161024_153307.jpg 20161024_153312.jpg
    Thoughts?
    Thank you!
  2. WastedTheLight
    16
    I swear, the easiest way to figure stuff out is to post the question and then go try again, haha. Turned out you hold the "Audio" button, not "Setup" in the Gen 3. This got me more menu options, but still no camera configuration. My aftermarket camera ties directly into the original head unit and works great, but the diagnostic area doesn't appear to see it?
  3. WastedTheLight
    16
    Will Carista allow me to modify the backup grid? Since I installed the camera off to the side and not dead center, it's a bit off. I thought I could do this in the hidden menu, but as mentioned above, there's no camera option. Thanks
  4. qdllc
    qdllc Senior Member
    1,358
    396
    My backup cam had a loop wire. If you wanted the "grid," leave it intact. If not, cut it.
    I didn't know of any "secret" menu on the Prius Two head unit.
  5. WastedTheLight
    16
    I definitely want to keep the lines, but was hoping they were adjustable. As you can see in the first photo, there's a camera button, but it's greyed out. Must be something extra special about the stock one that let's you get into additional settings I guess.
