2013 Prius v 12v battery dead
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by kellybarron, May 12, 2016.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,981
    Texas Hill Country
    You have to have a small screwdriver to do it. That's my screwdriver to the left in the above pic. Not likely to even get the cover off without one much less move the lever. Plus it's slightly down from the opening and hard to see without a flashlight. So all you Sopranos out there driving a Prius need a light and a screwdriver hidden back there
  2. kellybarron
    kellybarron Junior Member
    Oregon
    2013 Prius v wagon
    Thank you so much, that's what I needed to know. It worked perfectly. I didn't even see that tiny lever! I used a small, thin screwdriver to remove the access door, then a medium, stronger screwdriver to trip the lever.
  3. CR94
    CR94 Senior Member
    2,834
    1,244
    Northwestern S.C.
    On the 3rd-generation regular Prius, you can reach and operate the emergency release lever with a finger through the small access hole. Physically, that's easy, once you have your fingertip on the lever, although just finding it by feel takes me a long time every time I try it. The vagon is more difficult?
