2013 Prius V all dash lights on, won't start
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by maxthehammer, Jun 5, 2021.
  1. maxthehammer
    maxthehammer New Member
    2013 Prius v wagon
    Hi all,
    I have a 2013 Prius V with about 52,000 miles. Today, out of the blue, it won't start. The dashboard lights up with all the warning lights. The engine won't start. I can physically move the shifter but nothing happens.
    Any ideas? Much appreciated!
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,040
    6,920
    Texas Hill Country
    First thing to do is to check the 12v voltage under the hood in the fuse box. This is the jump start point. Hopefully it is 12.0 vdc or better indicating a decent 12v battery. Much lower and it is partially or fully discharged. If the battery is six or more years old, there is a good chance it is worn out.
    While the manual shows jumping with a car battery, the better and safer jump is with a lithium jump pack. Also note the red arrow, a badly discharged battery may need a few minutes of jump time to bring your battery to a decent voltage. With a jump pack, just connect and let it "charge" your battery for a few minutes if it does not immediately work.
    If this is the least bit confusing, stop and get assistance. A switched polarity can do serious damage.
    Tim Jones likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    $200 at auto parts
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,569
    2,602
    Taylors, SC
    #4 Georgina Rudkus, Jun 6, 2021
  5. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Got mine 3 years ago at Oreillys
  6. therealdana
    therealdana Junior Member
    the moon
    2013 Prius v wagon
    I've got this same issue. After replacing the 12V and the key fob battery, i have no luck starting the car. My local mechanic recommended me to the dealership for this issue. Before i tow it to the dealer, do you have any other things i can check? the hybrid battery is half charged.
    Do you think it's possible that the battery i purchased from advance auto isn't fully charged? It's from 11/21 if the sticker is correct. Could that be the culprit?
    #6 therealdana, Jan 11, 2022
  7. runnyeggs
    runnyeggs Junior Member
    31
    NV
    What's a good place for a battery nowadays? I cant remember if Costco sells my battery. Second option is Sam's/Walmart.
  8. Georgina Rudkus
    3,569
    2,602
    Taylors, SC
    Got mine at Batteries Plus.
  9. artistic_gore
    artistic_gore New Member
    24
    Washington State
    Costco sells Interstate batteries.
  10. Carl Mims
    Carl Mims Junior Member
    Bozeman, MT
    2015 Prius v wagon
    Not my experience with Duracell / Batteried Plus... purchased 18 months ago. Yesterday had similar issue. Read voltage at battery and it was 6.78. Disconnected from car and Charged with 30 amp charger for 5 hours. Reconnected. Same issue... battery read 11 volts.. so turned the headlight on for 1 min.. then off. Read 7v. So took to Batteries Plus. They said it was 11 volts and just needed charging on their special charger and would not give me a warranty battery until it had been charged by them for at least 24 hr. Keep in mind not at my home and is 45 miles away at my daughter's house. Very frustrated.
  11. bisco
    52,804
    unfortunately, most battery resellers are reluctant to honor warranty without a fight
  12. Georgina Rudkus
    3,569
    2,602
    Taylors, SC
    Time to talk to corporate and read them the riot act. Sounds like an errant franchised dealer.
