2013 Prius v Door Guard
Discussion in 'Prius v Accessories and Modifications' started by kjdunlap, Mar 5, 2013.
  1. kjdunlap
    kjdunlap Three Prii family 2013 V, 2013 C and a 2005.
    Kirkland, WA
    I am looking to purchase Door Edge Guards for my 2013 Prius v.
    I have found Part number PT93647100 but they say they are for Prius/Prius Plugin 2010-2012. How different are the doors? Will these work on a 2013 Prius v?
  2. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    Doubt they would work, door sizes are different from the hatchback and V models. I have made a second request to Toyota Door Edge Guards I have yet to hear if the V or even C lines will be available soon.
    I have had their door guards on previous cars with great results. Factory color matched and a perfect fit. They are a little pricey but worth every cent if wind catches rips the door from you or your passengers hands in a parking lot.
  3. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    I used the U-channel clear vinyl door edge moldings you can find at your local auto parts store for about $5. They're bendable and will conform with the doors' outline and did I mention they are CLEAR. They come in pairs and I've used them on both the front and rear doors.
  4. kjdunlap
    Kirkland, WA
    Thanks You sURFNmADNESS for letting me know that the doors are different sizes. KaliforniaKid, Clear sounds like a good choice until dirt gets trapped under the molding.
  5. teamsc10190
    teamsc10190 Stereo Prii (2011 and 2006)
    145
    63
    Prius C and Prius V door edge guards will be available probably within sixty days.
  6. teamsc10190
    145
    63
    Bring the part number to your dealer (he doesn't have it).
    2012-14 Toyota Prius V Genuine Door Edge Guard part numbers:
    PT936-4712V-01 (1F7 Classic Silver Metallic)
    PT936-4712V-02 (202 Black)
    PT936-4712V-03 (3R3 Barcelona Red Metallic)
    PT936-4712V-07 (787 Clear Sky Metallic)
    PT936-4712V-08 (8T5 Blue Ribbon Metallic)
    PT936-4712V-10 (040 Super White)
    PT936-4712V-11 (1G3 Magnetic Grey Metallic)
    PT936-4712V-20 (070 Blizzard Pearl)
    PT936-4713V-17 (781 Sea Glass Pearl)
    sURFNmADNESS and kjdunlap like this.
  7. teamsc10190
    145
    63
    2012-2014 Toyota Prius C Genuine Door Edge Guard part numbers:
    PT936-52120-10 (040 Super White)
    PT936-52120-20 (082 Moonglow)
    PT936-52120-01 (1F7 Classic Silver Metallic)
    PT936-52120-11 (1G3 Magnetic Grey Metallic)
    PT936-52120-02 (209 Black Sand Pear)
    PT936-52120-03 (3P0 Absolutely Red)
    PT936-52120-04 (4V7 Habanero)
    PT936-52120-07 (774 Summer Rain Metallic)
    PT936-52120-08 (8T7 Blue Streak Metallic)
  8. sURFNmADNESS
    199
    48
    Omaha, NE
    Thanks for the part numbers teamsc10190. I will have to check with my local Toyota in couple months or even watch the shop here to get them in.
  9. 1911Tex
    1911Tex Junior Member
    57
    17
    2013 Prius v wagon
    I guess I don't understand......my v5 came with door edge guards.
  10. teamsc10190
    145
    63
    They can't be genuine Toyota door edge guards that are stainless steel construction, coated in thermoplastic compound and then painted body color in Toyota paint pigments because they're not on the market yet.
  11. sURFNmADNESS
    199
    48
    Omaha, NE
    I had a treatment from the dealership of what they called door edge guards. It was just a thin strip of the same protective clear sheet they used on the front of the car. They are folded around each door. Paid about $15 a door for the treatment. They are not what I was looking for. The Adell's are like no other door guards I have ever had. Previously had them on a 2005 Dodge Quad Cab Pickup. Color was a perfect match to the factory color so you really did not know they where there like you see on the cheaper chrome/black ones commonly found around the web.
  12. sURFNmADNESS
    199
    48
    Omaha, NE
    Ok, I got a pre-release Adell/Toyota official door guards today and they look fantastic. I have been told they should be available via Toyota in about two more months. I have attached some pictures before and after install. Please note, I had opted for clear coat protection on the door edges like that found on the hood from rock chips. This slowed up the install phase by over an hour having to remove the left over glue.
    A couple quick tips to add to the instructions. In order to remove any glue or stubborn tar, use rubbing alcohol. Simply Green will just not cut it. Also if you use a common black headed rubber mallet, wrap it first in gray duct tape. This will keep the door guards from getting black marks from the hammer.
    Special Thanks goes out to teamsc10190 and Adell Corporation.
    teamsc10190 likes this.
  13. Air_Boss
    Air_Boss Senior Member
    3,915
    1,068
    New Yawk
    Interesting. What sort of material are they made from and how far do they protrude from the bodywork plane?
  14. teamsc10190
    145
    63
    The door edge guards are made from stainless steel; completely encapsulated in thermoplastic compound (so there can never be metal to metal contact), and then painted in original Toyota paint pigments. It's a completely unique product only available from Toyota.
    Maximum projection from the surface of the bodywork plane is 1.8 mm's
    Air_Boss likes this.
  15. Air_Boss
    3,915
    1,068
    New Yawk
    Thanks! What's the price point?
  16. teamsc10190
    145
    63
    Toyota MSRP is $109, but you can find Toyota dealers on ebay selling them for a lot less. Make sure you're buying genuine Toyota DEGs from a Toyota dealer because that's the only place you can get this stainless steel-based product. Door edge guards from any other source are not stainless steel construction, and they aren't perfect body color match.
    Aftermarket door edge guards are extruded plastic channels that are a lot bigger and they stick on the car with adhesive (that flows and oozes out in hot weather).
  17. Air_Boss
    3,915
    1,068
    New Yawk
    Thanks!
  18. sURFNmADNESS
    199
    48
    Omaha, NE
    Getting lots of complements at work from other car owners. Many checking out Adell's website out for versions for their cars.
  19. teamsc10190
    145
    63
    Great news! You need to explain to your friends that Adell can't tool DEGs for every car on the market, so they'll only have more popular models. Also; if Adell has an OE relationship such as with Toyota: the only place a customer can get genuine Toyota DEGs is through a Toyota dealership.
  20. mikefocke
    3,645
    1,628
    Sanford, NC
    Wonder what effect on mileage installing something that disrupts the airflow along the body surface brings?
    I make it a habit of holding onto the edge of the door as I open it and can's say I'd seen any chips on the edges of my doors on cars kept 9+ years and 70k+ miles.
