2013 Prius V needs navigation update
Discussion in 'Prius v Audio and Electronics' started by robrt, Mar 18, 2019.
  1. robrt
    robrt Junior Member
    chicago
    Am I correct that I need a dvd to update the navigation map in my 5 door 2013 Prius V? I keep asking the dealer for one, but never get any response. Any ideas of how I can get the latest update? My dvd is from 2014 and out of date. Thanks.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    There are two different nav systems in a Prius v depending on the model you have. The v5 is the higher end version. Either way, nav updates are only available at the dealer for a price, usually several hundred dollars. As far as I know, no one has hacked one with a duplicated nav file.
    I just go to the parts counter and they give me the current price. I am sure a service adviser can do the same but I have found some advisers are not on the top of their game. Sometimes that helps if they quote a normal spark plug replacement not knowing the work it takes on a Prius, sometimes it hurts when they can't troubleshoot a failing XM preamp while its still in warranty. Both happened to me.
    #2 rjparker, Mar 18, 2019
  3. mikefocke
    4,080
    1,862
    Sanford, NC
    Parts counter. Take a full wallet.
  4. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    The map update is not on DVD. Both 2012-2014 Prius v navigation systems are updated by a Toyota dealer tech using proprietary software. When you buy an update for these systems, you are buying only an activation card that has a code that the dealer tech enters during the update process.
    When we had the navigation in my wife's 2012 Prius v Five/ATP updated in early 2017, I bought the activation card through the Costco Auto Program for $143.65 (retail was $169) and then paid $40 for the labor it took to do do the update - both amounts exclude tax.
