2013 Prius V oil light flickering.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Dapriusv, Sep 26, 2025.
  1. Dapriusv
    Dapriusv Junior Member
    New York
    2013 Prius v wagon
    So recently the oil light started flashing every other day. I got the oil replaced and even replaced the oil pressure sensor just in case but the flickering still happend. I really dont know what else could be the issue. No signs of leaks and I check the oil dipstick and oil level is ok where it should be. Anyone can help me out and maybe pointing me to the right direction to check and find the problem. Thanks in advance!
  2. PriusCamper
    PriusCamper Senior Member
    13,360
    5,399
    Pacific Northwest, USA
    Please confirm your oil level is at the top of the dipstick before we help with further diagnosis. This is because once you get lo low oil levels sudden braking or turning hard on corners causes this type of flickering.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
    Check the wiring of the oil sensor switch.
    PriusCamper likes this.
