2013 Prius v vs. Pacifica Hybrid/ Tesla batteries and engine setup/design?
Discussion in 'Prius v Main Forum' started by S.Bell, Oct 29, 2018.
  1. S.Bell
    S.Bell Junior Member
    70
    Bay Area, CA
    2013 Prius v wagon
    I love my 2013 Prius v trim 5 fully loaded, but I am now curious as to the differences between it in a Pacifica Hybrid.
    Please feel free to answer the questions below on a Tesla, too.
    1. Due to the setup in my v, I cannot have a large inverter hooked up straight to my AGM battery and run anything more powerful than a cheap, small, “low wattage”, travel size hair dryer on low setting - unless maybe my v has been running in full gas/power mode for a few minutes. Would such an issue still exist in the Pacifica Hybrid? Why/why not?
    2. Why all is the Pacific Hybrid said to be more “powerful” such as better get up and go than my v? Yes, I do know that my v has a small, 85 cold cranking hours AGM battery, but I have been told that even if I changed out that battery for another battery, it would still be limited. Yes, I know that is large part of why v can’t handle large inverter with big wattage items plugged into it unless in Power mode/full gas, but I don’t remember why exactly that is scientifically.
    3. How is are the lithium/hybrid batteries different and same?
    4. I have learned the hard way that I must run my car every few times of watching a DVD in it on accessory mode or likely end up needing a jump start in my v. Would that still be an issue in the Pacific Hybrid? Why not? Obviously, I don't care to hook up an extra battery.
    5. While watching a DVD in my v on accessory/aux. mode does lower my mpg a bit, it has been worth it. Would having the plug in Prius or the Pacific Hybrid lower the battery energy from the regenerative braking or from the Plug In part or is it the same in the end?
    No, I am not ready to sell my v yet.
    Thanks in Advance for answering my questions.
    iPhone ?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Yes a 'normal' hair dryer is almost 2000 watts, and will over power almost any car electrical system. (some pickups may work)
    Due to a very small 12 volt battery, you are ill advised to ever run any electrical load except when in READY. If you are in READY, you can have a 1000 watt converter, if you wire it directly to the 12 volt system. The cigarette lighter plug is limited to about 100 watts, so only power these from the clips. (Or better, have your automotive electrician/stereo installer permanently install it, so it only works in READY)
    www.amazon.com/dp/B00T564EIY
    www.amazon.com/dp/B07BJHJB3J
    'Small' Hair dryer
    www.amazon.com/dp/B01AD0AOCU
    The Pacifica has a 3.6 liter engine, while the v has a 1.8 liter engine, so it makes more power/gets worse mileage. It also has a larger High Voltage battery 16 kWh vs the v's 1.3 kWh, so it can better spend time in an all electric mode, and needs to be charged by being plugged in. The size of the (tiny) 12 volt battery in the v will not impact you much once you internalize ALWAYS be in READY when using any electricity.
    Forget Accessory mode even exists, and you are golden. I do not think I have been in ACC since 2010, and have no plan to ever be in it again. While small, the Prius v 12 battery will set you back over $150. Don't run it down in ACC. Be in READY.
    (The Pacifica will have a larger 12 battery, that will also leave you stranded if you run it down. Be in Ready)
    The load from the DVD is the same and has to be made up for. With a Plug in, you can charge up the 12 volt battery with 'real' electricity as well as the bigger HV Battery, but yes, if the DVD is played while driving, that energy will lower MPG slightly
    #2 JimboPalmer, Oct 29, 2018
    jzchen and Pluggo like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,067
    6,936
    Texas Hill Country
    With a Prius or any hybrid, the most economical solution for long term use of accessories while parked is the Ready mode, allowing the HV battery do the heavy lifting, rather than installing a marginally bigger battery that just adds 10% runtime before it is discharged. Plus using the 12vdc battery system offline on a regular basis will cause deep cycling, dramatically shortening it's life.
    An alternative is to properly install a dual battery system with a battery isolator AND an automatic charging relay. The setup would be a little different than most sources illustrate. The automatic charging relay portion should include combined and isolated charging modes. The system should incorporate a low voltage disconnect feature. It should handle voltage lockout situations when one battery fails. Even then you should specify a new "second" battery outlet for items the second battery would run plus purchase a Marine AGM deep cycle battery. I would have it done with someone who does high end marine systems who also has a working knowledge of Prius 12v electrical systems.
    All of this is pretty expensive to install especially when you have one of the most efficient and quiet electrical power sources already installed, eg your existing hybrid system. And don't forget, even the best dual battery system still has to be recharged which will end up burning additional gas anyway.
    If I was fit to be tied and had to have more available battery power because I am camping in the garage and can't let the car run, then I might buy one of the new 120vac/12vdc lithium rechargeable power supplies and optionally include a solar panel for the zombie apocalypse as well. Probably less money and it might have some use with the boy scouts.
  4. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    Based on consumer complaints, the Pacifica hybrid is still a technologically risky car to own. It can shut down, overheat, burn out, etc. based on the complaints. You may want to hold off if interested until all the troubles are worked out. Owners are really scared of it dying in the middle of the road.
    15 Complaints: 2018 Chrysler Pacifica Hybrid Engine Problems
    9 Complaints: 2018 Chrysler Pacifica Hybrid Electrical System Problems
    The v does not have enough power and capacity to run much on battery alone. Consider investing in a power station. The lithium Yeti can power a hair dryer and still be charged from the car or solar. But very pricey. Around $1k. Costco carried them. Also heavy at 40lbs.
  5. bisco
    52,820
    did i miss the tesla question?
  6. bisco
    52,820
    you can install a 1000 watt inverter on your 12v battery, leave the car in ready, and watch all the dvd's you want.
  7. rjparker
    11,067
    6,936
    Texas Hill Country
    The thousand dollar Costco version is the Yeti 1000 wHs (watt hours) or 1 kilowatt hours (eg it could do 1000 watts for an hour). It still has a 1500 watt (max instantaneous) inverter. A typical 25 watt portable dvd player might run 40 hours on 1000 wHs. The $300 version in my post above is 500 wHs with a 300 watt max inverter and might run that DVD player for 20 hours. Both can recharge with solar, plugin AC or 12vdc while the car is running. It could take days to fully charge with 12v or solar and 18 hours with their small AC charger.
    Tesla Model 3s have a 50 kwh (50,000 wHs) so you can hide in the woods for weeks.
    You don't have a lithium battery in your hybrid. Some hybrids like the Prius Prime and Prius v's sold in Europe do have lithium. Of course we are talking the high voltage battery which does not discharge unless you are in "Ready". In general the lithium batteries have more kwHs in the same volume, so their capacity is larger, meaning it will run on EV alone longer, even when in Ready mode. All pure electric and most plug-in hybrids will have higher capacity lithium batteries.
    #7 rjparker, Oct 30, 2018
  8. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    I've thought about what is the best way to setup solar panels. This is an expensive option to consider but it will give a roomier place to sleep and plenty of space for solar panel charging while camping out.
    A rooftop tent. When you don't need the solar, just place it back in the rooftop compartment. Should be enough for 200-300 watt of evergy and can charge a 1kw Yeti in 3-5 hours in direct sunlight. The solar panels will have to be those thin flexible panels. Get the ETFE film panels. They should last 10-20years and only weigh a few pounds. Regular plastic film panels will yellow out over time.
  9. S.Bell
    70
    Bay Area, CA
    2013 Prius v wagon
    Thanks, everyone.
    I tried the Yeti 1400 from Costco but it's weight and size in addition to extremely long charge time just wasn't really doable. The set up of it was very helpful and super easy, especially getting my feet wet for the first time trying out a lithium generator and solar panel (which I learned wasn't the right panel type for me to continue with my needs)
    Now, I have the Kodiak inergy generator, which works out Pretty well but ends up having to be reset after most uses - at least without having a solar panel hooked up to continually recharge it more or less speaking.
    Kodiak inergy generator:
    The Kodiak inergy can Not be charged by the DC/,cig outlet in the v. It has to do with the peak amphrage and the fluctractions from how the car is set up and the changing of drive modes. I can't afford to drive in Power only. Plus, that defects part of why I got my wagon.
    So from there I got the 2000 watt inverter with extra heavy duty cables (in case of trunk gets stuffed with all kinds of stuff). I figured a bit bigger to cover hair dryer for in the winter time on our extended car camping trips. Yes, copper wiring. I did a big longer cables in case of replacement of the inverter later on or in case decide to shorten cables later on.
    I have been trying my best to not break down and buy a semi-permanent and semi-flexible panel due to finances. I'm at, 85,500 miles, too. I also have a panoramic roof, so I can just barely fit 100 to maybe 125 watt semi-quick, flexible panel above my trunk area of my roof. The edges of them would fit onto that slight roof edge.
    Needless to say, I do a great deal of car camping across the USA.
    Before I reply further, I will reread the posts above and any additional ones.
    Thanks again.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I think the inverter is protected by a 125 amp fuse. 12 x 125 = 1500 watts which is why I was not sizeing over 1000 watts, as you need some for the car.
    scona likes this.
  11. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    Always be in 'Ready' when using the inverter.
    Simba
