2013 prius v with stalling sensation
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Soniasmall1021, Jul 11, 2022.
  1. bisco
    52,904
    if it were the battery, you would have a trouble code
    Soniasmall1021 and Tim Jones like this.
    52,904
    did you clean the four small ports in the intake manifold?
    have you cleaned the battery cooling fan and intake grille?
    Tim Jones likes this.
  3. Soniasmall1021
    Soniasmall1021 Junior Member
    35
    United States
    2013 Prius v wagon
    I did clean the battery cooling fan like a month ago. It wasn't that dirty.
    We did not clean the intake manifold. I hadn't showed my husband that video yet. I mentioned it and it is one thing that he is a little leary of doing. He let's me know that he is by no means a mechanic. But it's that it's attached to the engine and he doesn't want to mess anything up!!
    It's just really weird that I can drive the car without the ac and it's fine, but the moment I turn it on, it starts having major hesitation in stop and go.
  4. Soniasmall1021
    35
    United States
    2013 Prius v wagon
    Bisco
    And thank you for all your help and suggestions by the way!!
  5. Soniasmall1021
    35
    United States
    2013 Prius v wagon
    I think I might check the 12v battery too! I bought it about 2 years ago. But I noticed my back up camera not coming on sometimes and the doors not wanting to lock. The last time that happened, the car ended up needing jumped off a couple weeks later then the new battery!
  6. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    A/C is electric, so auxiliary battery condition is an easy first issue to review.
    Soniasmall1021 likes this.
  7. bisco
    52,904
    check to make sure the a/c radiator cooling fans come on with the a/c
    Air_Boss likes this.
  8. Soniasmall1021
    35
    United States
    2013 Prius v wagon
    Ok! As soon as I find out how to do that!!
    Yeah I have been driving without the ac and it has been smooth, no issues with 45mpg and the hv battery stays between half and full.
    And by any chance, do you know the best time to check the 12v battery? I went to advanced auto after driving for a couple hours and they said the battery was good.
  9. Air_Boss
    4,261
    1,197
    New Yawk
    First check in the morning after an overnight rest. Not after driving and charging.
  10. Soniasmall1021
    35
    United States
    2013 Prius v wagon
    Thank you! I figured out how to use the onboard diagnostic. I turned it on this morning after it sat since 7 pm. So a good 14 hours. It said 12.5, then when I put the load on it, by turning the car on, it dropped to 11.2, .5, 12 then jumped to 14.2
  11. Mendel Leisk
    42,380
    12.5 through the car display sounds good, it’s likely higher though, and a digital multimeter reading with the car off is more reliable.
  12. Air_Boss
    4,261
    1,197
    New Yawk
    The 14 volts follows the auxiliary battery firing up the car electronics, HV battery relays, and charging system.
  13. Soniasmall1021
    35
    United States
    2013 Prius v wagon
    So I did check my ac radiator fans. They do come on with ac. I have been driving the whole week in 100 degree heat without the ac and the car has been normal!! So I am just at a loss for things to check for now. But thankfully I am still able to work, even if I am sweating like a pig!!
  14. Air_Boss
    4,261
    1,197
    New Yawk
    Is the electrically driven A/C system fully charged?
  15. Soniasmall1021
    35
    United States
    2013 Prius v wagon
    Probably not. We have never charged it in the last two and half years. Not sure if the previous owners did. It still runs cold so I didn't think that it would need it! But ‍IDK
  16. bisco
    52,904
    it doesn't need it. i still have the original after 10 years, ice cold. that's all that matters.
  17. bisco
    52,904
    i would get a leak down test done
