2013 Prius wiper dead
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sabrina seafoam, Dec 8, 2024.
  1. sabrina seafoam
    sabrina seafoam Junior Member
    Indiana
    I have voltage on the plug on separate pins for low and high replacement of motor did not help
  2. sabrina seafoam
    Indiana
    Ground is good voltage to motor I must have bought a bad part from Oreileys
  3. ASRDogman
    ASRDogman Senior Member
    7,932
    4,039
    If you apply power to the motor, does it work?
  4. sabrina seafoam
    Indiana
    I’m getting 13v on the plug i haven’t tried taking the motor off
  5. sabrina seafoam
    Indiana
    I had it off t mech and plugged it in no run
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,756
    6,750
    Texas Hill Country
    Try these tests
  7. sabrina seafoam
    Indiana
    Thanks for your help. Knowing the pin layout made it easy I don’t have the voltage where it should be. Ordered switch from eBay hoping for fast response.
    Thanks again
