2013 Prius Wobbles at certain POWER settings
Discussion in 'Gen 3 Prius Technical Discussion' started by Abraham Vines, Sep 28, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    8,039
    4,074
    A .22 gun bore brush in a drill, with gunk works very well!
  2. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    That's an excellent idea, I should have done that when I was cleaning mine awhile back.
    ASRDogman likes this.
  3. Mendel Leisk
    42,255
    Brushes for cleaning stainless steel drinking straws work good too. Google slim bottle brush on Amazon, you'll likely get a deluge of options.
    I didn't bother with a power drill (overkill?), just insert the brush a bit, then tuck in the straw from brake cleaner can, give a squirt, work the brush.
    CR94 likes this.
  4. ASRDogman
    8,039
    4,074
    The bore brush has stiff bristles, and can clean out the carbon, used with Gunk.
    With the drill, you can run it through each hole for 5 seconds and be done.
    You don't need run it at a high speed, unless you want too.
