Discussion in 'Newbie Forum' started by Al h, Nov 7, 2021.
  1. Al h
    Al h Junior Member
    35
    Nj
    Ancel AC310/OBDII/EOBD+CAN
  2. Al h
    Al h Junior Member
    35
    Nj
    Correction: Ancel AD310/OBDII/EOBD+CAN
  3. ChapmanF
    19,035
    The repair manual can definitely provide a lot of advice on diagnosing the evap system. So can some other quick technical guides and technician course materials also available on TIS for no additional cost.
    Evap system diagnosis can be kind of involved, and there can be some rather specialized tools for it (such as very carefully designed low-pressure regulators for an inert (!!) test gas like nitrogen).
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,118
    6,975
    Texas Hill Country
    You are smelling gas. Go look for it before getting too technical.
  5. ChapmanF
    19,035
    Oh, I missed the post about smelling gas, 'cause it was pretty far upthread.
    Bunch of posts after it wondering why the codes haven't gone away, but if there's still a gas smell, that's why.
  6. JC91006
    16,936
    8,647
    If you aren't using an original gas cap from Toyota, that could be a very good reason why you're smelling gas. The aftermarket stuff is not very good.
  7. Al h
    Al h Junior Member
    35
    Nj
    Thank you all for your suggestions! I ordered a Toyota gas cap, hopefully that solves the 2 codes. If it persists, I will take it to a shop and they can lift and hopefully find a leak.
  8. Al h
    Al h Junior Member
    35
    Nj
    Took it to a shop and they said it’s the purge valve. They replaced the purge valve and after 2 days the check engine light turned back on. Not sure if they are crooks or if that was one of the issues.
  9. Mendel Leisk
    42,355
    I'm not sure what that means; is the current gas cap on the car stock Toyota, or?
    Could be.
    Backing up: you replaced the gas cap? Due to defect in the original, or it got lost?
    I'd get the Toyota cap first, say from a dealership, see if that helps.
    Ok, see you're on that.
  10. Al h
    Al h Junior Member
    35
    Nj
    I replaced the gas cap for an original, still didn’t help.
