2013 Scion FRS Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by firemechanic, Feb 1, 2013.
  1. firemechanic
    firemechanic Junior Member
    Kent, Washington
    Just bought a set of Scion FRS wheels from my local Toyota dealership. They upgraded the wheels on four new FRS's and sold the wheels on Craigslist. I got a set for $400. Brand spanking new Michelin Primacy HP tires with rims and center caps. I will include a pic when I put them on. 2013-scion-fr-s-wheel-tire.jpg
  2. PriusCamper
    PriusCamper Senior Member
    13,476
    5,443
    Pacific Northwest, USA
  3. joey185
    joey185 Junior Member
    24
    Oregon
    Four Touring
    Pics yet?
  4. firemechanic
    Kent, Washington
    I'm trying to squeaze the last 2-3K miles out of my old ones. I put 30K a year on the car so it should'nt take long.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Great deal! Any mpg loss from the non-LRR tires will be made up for by the fact you basically got the tires for free! :)
  6. Chris S
    Chris S Active Member
    323
    111
    Gilbert, AZ
    I agree, what an awesome deal for wheels that look good! Congrats. Did you sell your originals? It'd be nice if in the end you made out with free wheels and tires :)
  7. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    Crazy deal! Especially since it's coming from a stealership.
    Ajwatuc likes this.
  8. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    My thoughts exactly. ;)
    Ajwatuc likes this.
  9. firemechanic
    Kent, Washington
    My original MOMOs may get some winter tires........if I can find a deal. As far as the gas mileage, my last set were Michelin Primacy LRR MXM4 215/50 17's and I dropped about 4-5 MPG. Hopefully this new set is at least equal......time will tell.
    It was a great deal. If I had gotten there earlier I would have bought the other sets. Someone bought the others at the same price and I've seen at least one of the sets relisted on the local Craigslist for $850
  10. swich2mac
    swich2mac Go Hard or Go Home!
    319
    38
    Franklin, TN
    Where are the pics? I'm curious to see as I just purchased a new set of those wheels for $480. I'm going with the same Michelin MXM4's that you just put on yours. I don't really care about the mpg hit as much as I do a smoother and quieter ride! ;)
  11. swich2mac
    319
    38
    Franklin, TN
    Hey F8L, what over inflated front/rear tire pressures do you recommend? Also, can I assume that I can use my existing lugs and center caps off my OEM 15's?
    I also assume that my speedometer will be off and did you ever estimate by how much?
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm running a set of CT200h wheels w/Michelin MXM4 215/45/17 & my Speedo is off by 3mph.......I'm also seeing a 3-4 mpg loss over my 15's.
    James Powers likes this.
  13. swich2mac
    319
    38
    Franklin, TN
    Ok, so if the speedo says 70, the radar should clock you around 73? In theory...
  14. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I run 40 rear, and 38 front (just for a bit more oversteer) :p...
    And you need new lugs (15" lugs) are too wide
    Also don't forget a set of (4) 3mm spacers
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    For comfort and mpg I'd try 40/38 or 38/36 and see how that feels. You're not going to gain much by going a lot higher so you may as well enjoy the ride at lower pressure. :)
  16. swich2mac
    319
    38
    Franklin, TN
    Oh boy..... so can I assume that the tire shop can provide me with lugs and spacers ?
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    It's the other way around.
    If ur speedo shows 70mph the radar will have u at 67mph
  18. firemechanic
    Kent, Washington
    Here is a pic with the new Scion wheels on. I had to add 3mm spacers so that they cleared the calipers. GPS reads 1 MPH slower than the speedo. They ride quiet and handle just fine. I will let you know about the MPG #'S later.
    Does anybody have a good source for spacers? I just used 3mm thick grade 8 washers until I fine a suitable spacer. I used the spline drive gorilla nuts, from my old MOMO wheels, to hold them on.
    snead_c likes this.
  19. swich2mac
    319
    38
    Franklin, TN
    Oh man, those look sweet! Glad I went with 'em and that dark interior portion of the wheel will look great on my winter gray!
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    They look really good........now u need to take care of that ugly wheel gap ;)
    mnml likes this.
