2013 Suspension
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kiiing, Jul 1, 2021.
  1. Kiiing
    Kiiing Junior Member
    Brooklyn, NY
    Hi everyone,
    I own a 2013 with approximately 160k miles. I'm looking to change out the front struts and springs. I'm going with the KYB full assembly. Is there anything else that I might as well replace or should be replacing? Any tips would be highly appreciated. Thanks in advance
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Stabilizer links and possibly strut boots
    Paul E. Highway likes this.
  3. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    Stabilizer bar bushings. I would also change out the Strut mounts
  4. SB6
    SB6 Member
    324
    71
    The KYB assembly comes with new mounts, no?
  5. bluhawk
    bluhawk Junior Member
    25
    Torrance, CA
    and strut boots, no?
    SB6 likes this.
  6. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    Depends on how you buy them? If you order as an assembly then yes which also comes w/ new springs. If just the strut, then no.
    Just checked Rockauto, Strut itself is $72, as assembly $148
  7. ASRDogman
    ASRDogman Senior Member
    7,977
    4,049
    It will cost less to buy the complete assembly then parting it out. I've already checked.
    If you only buy the strut, you're intalling it with an old bearing, bumper stop, plactic guard, which both
    are usually torn up, and an old spring. Springs do weaken.
    Then you have to take it apart, and put it back together. Which takes a lot of time.
    Easier and faster to remove the old one, install the new one with all new parts.
    tweedle99 and Mendel Leisk like this.
  8. Paul E. Highway
    Paul E. Highway Active Member
    210
    130
    Hawaii
    I bought the ‘complete KYB front strut assembly’ from 1A Auto and the strut mount was not KYB, they subbed cheaper unit, instead of heavy duty rubber on top it had flimsy felt tape. I had ordered the KYB mounts earlier intending to use original spring but returned them when I decided to go the complete assembly route to save time.
    Made me wonder what spring they used! They also shipped the two units in a huge box without padding or bubble wrap so the 2 units bounced around in box all the way to Hawaii.
    Spending my Prius $$$ elsewhere since.
  9. ASRDogman
    7,977
    4,049
    Are you sure they were kyb?
    I've been disapointed with 1a auto. They are too expensive. And slow.
  10. Paul E. Highway
    210
    130
    Hawaii
    Struts were definitely KYB.
  11. ASRDogman
    7,977
    4,049
    But you said the strut mounts weren't kyb???
  12. Paul E. Highway
    210
    130
    Hawaii
    Correct, the actual strut was KYB, the mount at top was not, and I have my doubts about the spring.
  13. ASRDogman
    7,977
    4,049
    That's weird. Seems if you get a complete strut from KYB, it would be the whole thing.
    Maybe they just took the strut and used whatever they had to make a complete strut....
  14. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    RockAuto is my go to source. They can be a few bucks more but at least they'll back their products.
  15. Kiiing
    Brooklyn, NY
    Is it the KYB SR4246 & SR4245? This is what I plan on getting. Thanks
    Can you tell me which stabilizer links would be best ? Should I go with OEM?
    Which brand would be best for the stabilizer bar bushings?
    #15 Kiiing, Jul 9, 2021
  16. Paul E. Highway
    210
    130
    Hawaii
    I got Moog stabilizer links, reasonable price and have grease fitting at each end. I shoot a little grease in there when I rotate tires. Also, I used the OEM bushings.
    douglasjre and Kiiing like this.
  17. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    The part numbers look right for the strut assembly
    Rockauto 5% off Expires Aug. 8, 2021
    175744774109682775
    I went w/ Moog bushing too since i was buying from Rockauto anyway. No need to runaround.
    Make sure you clean the bar very well
  18. Kiiing
    Brooklyn, NY
    I went with mevotech stabilizer links. They were a little bite more, but I seemed to have found better reviews on them. I couldn't find the OEM bushings so, I went with Moog. Just hoping these parts hold up as well as the OEM.
    I just placed my order. I found a code online, but used yours instead. I went with the Moog bushing. Pretty solid website. I was able to pick up a cardone wiper motor, too. Price was cheaper than anywhere else.
    tweedle99 likes this.
  19. douglasjre
    douglasjre Senior Member
    2,236
    747
    Null, NL
    Why would you change the strut mounts and why would you not change the sway bar links
