2013 TOYOTA AQUA ERROR P0A80 33393 KM
Discussion in 'Prius c Technical Discussion' started by Jamaikon, Feb 12, 2019.
  1. Jamaikon
    Jamaikon New Member
    Jamaica
    I pulled this error from my scan tool today.
    Bought the car in December from a used car dealer.
    Got the error last month P0A80
    Went to Toyota Jamaica, am not covered under warranty because I bought an imported Japanese domestic imported to Jamaica and they don't sell hybrids.
    Am stuck with this error and can't afford a 5900USD battery.
    Does anyone know where I can get modules to buy?
    I need to disassemble, load test and replace bad cells/modules
    Outside of Japan this car is called a Prius C
    What load do I add for load test?
    I found cheaper batteries but they won't ship.
  2. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Ouch, that's going to be difficult. There are a few users on this site who deal in modules, but I don't know if any of them have a way to ship into Jamaica.
    Have you tried connecting to the car with Techstream software? I haven't used it yet myself, but I understand that it can use the built-in diagnostics to an advanced degree and give you a good picture of what you are up against on a block-by-block level.
  3. Jamaikon
    Jamaikon New Member
    Jamaica
    Tell me more about techstream, also connect me with sources for buying modules, I have a US address I can give to send it to me.
  4. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    I don't have Techstream yet myself, but from what I have read I understand that this is Toyota's own diagnostic software. There are pirated copies of an older version available on ebay along with the cable required to connect the car to a laptop. The best recipe for success appears to be an older PC laptop with a 32-bit version of windows 7 on it. Keep that laptop off the internet, just use it for the car.
    Because it is toyota's own software it goes beyond basic OBD-II and allows much more detailed information to be pulled from the car's computers.
    I know there are a few people and companies selling modules but I've never bought or sold any, so I don't know which ones are good.
  5. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    Also - late reply, but if you can use an Android phone, or an iPhone, you can get OBD-II scanners that plug in and use WiFi or Bluetooth. I am sure Techstream is better, but I can still see live data for all batteries and systems on my Prius and Leaf, including realtime current, voltage, internal resistance, and dozens of variables. If using iPhone you need a Wifi-capable OBD-II device, but for Android you can also use Bluetooth.
    PM me as well as replying if this seems an easier option (if you have the phone, or tablet, the device is pretty cheap via eBay) :)
    P.S. My girlfriend has a Prius C (I convinced her to switch from a BMW) so I can probably give more advice if needed!)
  6. Jamaikon
    Jamaikon New Member
    Jamaica
    I have a ODB SCANNER via Bluetooth and it says blocks are bad, see picture... Note that this is a Prius c so the readings after block 10 may not apply, am not sure.
  7. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Ignore blocks 11-14, they don't exist in c models.
    ztanos likes this.
  8. Yasir Majeed
    Yasir Majeed New Member
    Pakistan
    2012 Aqua
    Two Eco
    Can any one tell me what's the life of hybrid battires for Toyota Aqua. When I purchased last owner replaced the battery after that I drive 110k Km.. Now my aqua giving error P108 replace the battery.. Yesterday I check with macanic all Cells showing 16.22 and 16.23 only 2 cells giving reading 16.16 '16.15 Please help..
  9. Rickalo Rose
    Rickalo Rose Junior Member
    Jamaica
    Hello Jamaikon, did you resolve this issue? Where in Jamaica are you?
  10. Jamaikon
    Jamaikon New Member
    Jamaica
    It's not resolved, am in Kingston
