2013 US: Check Hybrid System message after heavy rain
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sandblast7070, May 25, 2026.
  1. Sandblast7070
    Sandblast7070 New Member
    Hello everyone, I am a relatively new Prius owner and I am having some trouble figuring out how to diagnose my problem.
    One way or another, during a recent thunder storm rain seems to have gotten its way underneath of my spare tire, and possibly even inside my hybrid battery. The 12v battery seems dry, and none of the fabric trim seems to be wet. I did have the fabric trunk latch + plastic bucket trim out so the spare tire was visible from the trunk. I am confused though, as my weather stripping seems to be fine. I want to run some water over the closed hatch to see if I can find some sort of leak but as of current I have not identified any problem areas.
    When trying to start the Prius I am presented with the display saying "Check Hybrid System, Stop the vehicle in a safe place". There is a triangle with an exclamation point, the ABS light, the odd yellow light that has the car with the lines and another red light I believe also is on. I can't remember at this time but I will try to update tomorrow.
    I have an OBDII reader that only showed the code C1259. I have seen an app called "Dr. Prius" recommended on these forums, and I am currently researching what adapter I should purchase for that. Recommendations are appreciated on that front.
    I tried a couple YouTube videos that had troubleshooting steps. One of which said to pull the orange safety tab off the HV battery, then unplug the white wire (in the front hood fuse box) for 10 minutes. The other which said to turn on the car, put a paperclip in top pin 4 and bottom pin 5 of the OBD plug, press the break 8 times, wait 5 minutes, turn the car off, unplug the wire, wait 20 minutes, and then power cycle the car 3 times. Neither of these methods worked.
    Is there anything else I should / could do in the meantime to troubleshoot and / or prevent damage? I pulled the fabric cover off the battery and felt water underneath of it on the plastic side, and using my flash light I believe I see water underneath the hybrid battery. Again, I am unsure how this even happened. The rest of the car seems to be dry. I do work on my own cars, although this is my first hybrid so I am a bit fresh.
    Thank you, hoping my Prius pulls through without too much damage
    Sandblast7070
    PS; I took the car to the dealership for a recall last week. Something in 2018 about the battery stalling, would that be related if the problem is not water related?
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    You need a scanner that can read ALL the codes.
    It is possible there is an inverter issue. Or the inverter coolant pump. But you need more
    information, thus, a better code reader.
    The weather seal may look good, but that doesn't mean it is. It's common to leak in and down
    toward the 12v battery. It's not very likely it got to the hybrid battery.
    Have you checked all the fuses?
    It "might" be related to whatever the dealership did.
    Be careful about jumping wire from youtube, you could cause serious damage.
    Fabric on the hybrid battery? Do you mean the "trim" pieces?
    The hybrid battery is encased in a metal box. If you see/feel water, perhaps one of the door seals
    have failed. Or the rubber plugs on the bottom frame is missing.
  3. Brian1954
    Brian1954 Senior Member
    2,687
    1,073
    South Central PA, USA
    As already mentioned, you need a scanner that can read all the trouble codes. Look at post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    I recommend the Autel maxi AP200. It is a Bluetooth OBD2 dongle that uses an Autel app on your phone or tablet. It costs about $60 on Amazon.
    A thread that is specifically about the Autel AP200 is located here, https://priuschat.com/index.php?posts/3248209
  4. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    Rainwater coming off the rear of the roof and the sides of the hatch runs into the gutter-like channels under the sides of the hatch. At the bottom end of that channel, the drainwater is supposed to flow between the taillight assembly and body sheet metal. Unforturnately, the passage behind the taillight tends to become plugged with pollen and other debris dropped by trees---assuming you park near trees. As a result, the water leaks into the interior. When that happens on the right side, the 12-volt battery ends up in a puddle of water. The solution is to remove the taillight and clean out the junk behind it.
    That wouldn't explain water under the large NiH battery, if you really have that. Leakage through the seal where wiring enters the hatch may be a possibility.
  5. Sandblast7070
    Yes, the fabric trim carpet pieces that cover the hybrid battery metal box case. I felt water on the plastic side of the fabric trim.
  6. Sandblast7070
    I've been researching this device for the past couple hours or so and the product seems extremely anti-consumer. Only works on one device and on one car, otherwise needing a $22 subscription, and it also seems it only works with their app which is always online.
    Are there any other devices that can be recommended? Possibly a full AIO OBDII scanner that doesn't require a subscription or proprietary app?
  7. Brian1954
    2,687
    1,073
    The Autel app can be installed on more then one device. I have the app installed on my Android phone and on my Android tablet.
    If you do a scan on your phone, the information for that scan will only show up on that phone. It will not show up on the second device. The first car brand (Toyota) is free. Any additional car brands (Lexus, Ford, Chevrolet, etc) have a yearly subscription fee. If you own three Toyotas, Prius, Corolla, 4Runner, etc, they are all included with the brand of car that you picked (Toyota).
    The Autel AP200 Bluetooth dongle will only work with the Autel MaxiAP200 app. It will not work with any other app. You need to create an Autel online account. To use the app, you need to be connected to the internet and login to your Autel app by using the email and password that you used to create the Autel online account. Once you have logged into the app, you then do not need to be online for the next seven days. When you get to day number 8, you will need to connect to the internet and login to the app again. So, you need to connect to the internet one time every week that you need to use the app.
    If you are interested in an all in one scanner, take a look at the xtool D7. It costs about $350 on Amazon. Other similar priced are all in one scanners are also available.
