2013 w/ <90k - Short Block Replacement - Perfect Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATXpriusATX, Feb 21, 2020.
  1. ATXpriusATX
    ATXpriusATX New Member
    austin, tx
    My 2013 Prius (four) has 87,700 miles on it and is burning 1 quart of oil every 1,100 miles! I have a perfect maintenance record with the oil always changed in time, yet theres carbon blocking the piston seals. I don't have an extended warranty, so the dealership wants to charge me $6,650 to replace the short block. That's a big chunk of what the car is worth.
    Evidently this a known design flaw of this engine, and I have never missed a service. Seems like if I'm lucky, I might get someone at Toyota to cut me a break...
    Any suggestions?
  2. Trace
    Trace Junior Member
    I had 2010 that did the exact same thing. It started burning oil at that rate around 120K miles. I just kept feeding it until 170K miles at which point a tree fell on and crushed the car. Turns out 2010's were know to burn oil. I now have a 2013 Prius V. It is at about 175K and burns about 1 qt every 15-20k miles. The only maintenance it has seen is oil change every 15-20K. I replaced the head gasket and cleaned the EGR myself at 130K and water pump/thermostat at 172K. Nothing that should impact oil consumption.
    IMO, for $6K I'd just keep feeding it oil. When my head gasket went, most private Prius shops did not want to do a head gasket only and jumped to quoting me $4500 - $6900 for a used engine junk yard engine.
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    You can always buy extended warranty at anytime, if searching the internet is an option.
    SFO likes this.
  4. Mendel Leisk
    42,092
    Short blocks are around $1900 USD cash-and-carry. Gasket kit, new head bolts and various shop supplies maybe $400. Machine shop inspection of the head $400?
    For experienced pros with all the right tools and equipment doing the swap it's for sure less than a days labour,
    I'd look for an independent shop, and maybe research and procure the parts yourself. Take advice from the shop, and they likely have machinist preference.
    Cosmo Tigato likes this.
  5. Leadfoot J. McCoalroller
    8,190
    7,697
    Pennsylvania
    2018 Prius c
    Get it away from the dealer! Not the right place to take an older car for maintenance or repair.
  6. bisco
    52,592
    Search here for class action lawsuit
  7. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Another reason why all should clean the egr circuit and occ it even with lower miles on the clock.
    #7 Grit, Feb 22, 2020
    Cosmo Tigato and mjoo like this.
  8. Rmay635703
    Rmay635703 Senior Member
    2,678
    1,709
    Somewhere in Wisconsin
    2013 Chevy Volt
    It still runs right?
    Catch can, egr clean and keep the oil topped off.
    keep on truckin and don’t repair a thing
    If you live if a year round hot area consider some SN+ rated SAE30 weight oil to slow the bleeding
    tankyuong likes this.
  9. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Straight 30w oil baby, it’s racing time!!!
  10. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    No tire rotations nor coolant changes :eek:
  11. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    Ps. Reconditioned short block 779USD. Reconditioned cam 549USD. Is that cheap or what?
