2013 with 17" tires and wheel
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Joseph T., Mar 8, 2019.
  1. Joseph T.
    Joseph T. New Member
    San Jose, CA.
    Hi all
    I have Niche 17" wheel with 8 " wide. Currently have Michelin 215x45x17: too low profile and too much noise.
    I want to put 225 or 235x55x17. Would it be possible ?
  2. JC91006
    16,936
    8,647
    I believe the largest size you can put in there is a 225x50x17
  3. Joseph T.
    San Jose, CA.
    Thanks. No body can tell me excactly. Even Tire rack. All they said is to sell only.
  4. Mendel Leisk
    42,347
    If harsh ride is your main concern, go back to the stock 15" size?
    PA Prius likes this.
  5. Joseph T.
    San Jose, CA.
    Thanks, If I want go back to 15" I would do it long times ago. Don't need to ask question and post on Forums
  6. Joseph T.
    San Jose, CA.
    Thank you. Have you ever tried or know some one install that size in 2013 Prius ? Any scrub, rub on tires ?
    Thanks again
  7. Godzuki
    Godzuki Active Member
    133
    114
    Bay Area, CA
    2015 Prius Plug-in
  8. Joseph T.
    San Jose, CA.
    Thank you, Ride quality ? I am thinking about 215x55x17. But I wlll wait cause the Michelin tires still look new. Just I don't like the ideal of the rims IMG_2494.jpg is show out more then the tires. Just like them "youngter" this day.
    Beautifull color. My wife love this color.
  9. Godzuki
    133
    114
    Bay Area, CA
    2015 Prius Plug-in
    The ride quality on 205-55/17s is a bit more harsh over bumps than the standard 195-65/15s. Plus, the tires I have are rated XL (extra load), which has a stiffer sidewall than an SL (standard load) rated tire.
    Since you don't like the look of the rims extending further out than the tire, then you should probably go for a tire that's wider than what you have now, such as a 225 tire. As far as the profile, 45 is prob where you want to be so that it doesn't look like you have too tall of a tire. There are web-based tire size calculators that will permit you to compare the circumferential size of tires of different sizes. A 205-50/17 is comparable in circumference to each of the stock sizes 195-65/15 and 215-45/17.
  10. Joseph T.
    San Jose, CA.
    Thank you very much.
    Very well details information.
    My problems is NO tires shop around San Jose area willing to try out the tires fit first.
