2014 Backup Camera but not on Display
Discussion in 'Gen 3 Prius Audio and Electronics' started by PamW, Apr 17, 2016.
  1. PamW
    PamW New Member
    Alabama
    My son bought a 2014 yesterday and it has a camera on the back end (like my 2010) but it does not show up on the display. Did Toyota put cameras on some of the Prius' but not attach if you did not buy Navigation? That is basically the only difference between his car and mine. I can't understand why they would put the camera expense if it did not operate. Thanks!
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Is the camera showing up in the "rear view mirror"? One poster here on PC says his Prius is setup like that. I don't think he has the nav on his Prius either.
  3. Mendel Leisk
    42,306
    Maybe me? Ours is like that: no nav, back up camera in rear view mirror. But a US level 4 would have the backup in the Multi Function Display I think. Probably something disconnected or broken.
  4. PamW
    PamW New Member
    Alabama
    Not in the rear view. Guess he has an electrical issue.
  5. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Just to confirm and eliminate the silly obvious.. You are putting the car in reverse mode when you are expecting the back up cam to turn on correct?
    If that is not the case then bring the car in for warranty work? Still under warranty right?
    What kinda sucks for us 2014 owners (we own a 2014 v three) is that the 2015's+ all have back up cams on all models, thus making the difference between a two and three even less (needing a back up cam and upgrading to a three used to be a selling point, now it's on all the models)...
  6. PamW
    PamW New Member
    Alabama
    Yes, I personally made sure it was being put in reverse. (I drive a 2010 with the camera). Is there a way he can call Toyota to make sure the VIN has a backup camera installed. For the life of me I can't see any other reason why there would be a camera lens on the back of the car exactly where mine is.
