2014 C2 Keyed Ignition Problems
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Goose316, Jun 8, 2015.
  1. Goose316
    Goose316 New Member
    Cincinnati
    2014 Prius c
    Just got the c, only 1000 miles now. The car has done this twice, I insert the key and it won't turn. It just locks.
    Not sure what's causing it and I haven't exactly figured out how to fix it when it does happen
    52,784
    have you tried wiggling the steering wheel? how about the spare?
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    How will wiggling the spare tire help? :confused: :D
    Yes, maybe the steering wheel lock is engaged. While turning the key, try moving the steering wheel to the left or right.
  4. Goose316
    Goose316 New Member
    Cincinnati
    2014 Prius c
    That did seem to fix it today, I wasn't sure why though.
    However, I thought when I wiggled the wheel, it caused the problem the first time .
  5. xliderider
    8,140
    3,278
    Honolulu, HI
    Turning the steering wheel with the ignition off will definitely engage the steering wheel locking mechanism. However, if the wheel lock is engaged, especially when parked on a grade, then sometimes you have to tug on the wheel a bit to get it to unlock while turning the key.
  6. Goose316
    Goose316 New Member
    Cincinnati
    2014 Prius c
    T
    thanks, I'll give it a try next time.
    I bet I bump the wheel (bottom of the wheel and my thigh rub) when I get in the car and engage the lock.
