2014 Camry hybrid (back and smarter)
Discussion in 'Toyota Hybrids and EVs' started by Kikto, Jan 14, 2020.
  1. Kikto
    Kikto Junior Member
    Dover
    2002 Prius
    So, I had a post way back when of a gen 1 Prius id bought and I wasn't mechanically or technologically inclined as I am now. But here is what I've been doing. To sum up, I've posted in another forum which I won't link, but I didn't get much... Help over there.
    Summary: a dying battery which I believe really just needs a recondition, car enters limp mode (ICE always on) and it eats gas. I tried sitting with the battery out on my table for 4 days, discharging to about 1v to charging to 8+v put it back in with no balance and it got worse. Next, tried balancing it after I failed to charge it. I have a sphegatti monster photo here.
    Right now I'm using this (HTRC T240 Duo) to auto cycle 5 times because I think capacity is the problem, I have 4 cells I bought off Amazon. 1 I bought off eBay. I am dropping each cell to .5v and it's recording capacity in mAh which is weird because it says I only have like 900mAh which doesn't sound right...
    Anyway, short story short that's where I'm at. Continue on for all the other stuff I did on the car.
    I replaced all the lights with LEDs because I hate putting unneeded stress on charging systems plus they're bright plus they last FOREVER! I had changed the spark plugs because my upstream O2 was reading 16 and that was not cool so afterwards I got it down to about 2 - 5 which is fine. The valve cover gasket is toast, it's a NYC taxi cab and was definitely treated like trash. They got gasket material all over the valves and cleaned it up, I'll replace the gasket once I save up, I'm poor lol. The 3rd spark plug hole had a lot of oil, definitely needs a new gasket but I tried to recondition it as best I could and it's down to a small trickle of oil which I think is fair. The holes on the top of the car were all body filled and it doesn't leak like I'm driving in the ocean floor. There's still a lot of weird wiring that needs to be cleaned up and I plan on cleaning the engine, inside, out. Why? I love projects. The e-cvt or Power Distribution thing... Got emptied and refilled, the oil was BLACK, was absolutely surprised when I didn't see metallic pieces in there.
    Future projects:
    - I have to get new door gaskets a lot of them are broken, this'll probably help with the condensation that keeps getting in.
    - get all the stupid screws out that they just blasted in, like seriously, screws? Really?
    - ripping out all the carpet, plastic, and covers and cleaning them up and/or replacing them if need be.
    - suspension is definitely a problem haven't looked underneath yet but I can FEEL it.
    - tires are the cheapest things you can buy, I want this thing to be able to handle snow, sleet, water, hail, apocalypses.
    - lastly paint it myself, and put my YouTube channel on the side of it.
    Also, this car was $1100 and it's got 326k on the clock. I want it to reach 1 million at all costs. I'm also keeping it exactly how it is, it has the divider for the passengers and everything, I love this thing, it's comfy, it's fast for a dying battery, auto climate is a game changer. I love it more than my 50k miles 2015 Chrysler 200, and when I get this bad boy running 100% I'm going to be so happy!!!
    SFO and Cyvan like this.
  2. Kikto
    Kikto Junior Member
    Dover
    2002 Prius
    Update, I was talking to a guy in Virgina which, he does this for a living. Told me I had a gen 3 cell which... It was. All the cells I have currently look original from the car, I have all the serial numbers written down. 2 of the modules I thought were bad were bad, the other 2 are good. I can't really tell their capacity because my charger is set to stop at 7200mAhs which I thought was a good set point but now I'm kinda confused, they go higher? I'm doing one last cycle test before I go to bed and start cycling the actual cells in the frame. What SHOULD the limit be? I do need a baseline to get all the other cells to be somewhat aligned with the highest cell. We'll see, any of you doing this, notes notes notes, it helps SOOO much. I numbered all my batteries and there are some that I bought off Amazon that look... Weird. Here is my notes:
    1: 219RMM09519QMB1
    2: 219RMM09520QMB1
    3: 219RMM09521QMB1
    4: 219RMM09522QMB1
    5: 219RMM09523QMB1
    6: 219RMM09524QMB1
    7: 219RMM09525QMB1
    8: 219RMM09526QMB1
    9: 219RMM09527QMB1
    10: 219RMM09528QMB1
    11: 219RMM09529QMB1
    12: 229R1N11660QMB2
    13: 229R1N11676QMB2
    14: 229R1N11677QMB2
    15: 229R1N11678QMB2
    16: 229R1N11661QMB2
    17: 229R1N11674QMB2
    18: 229R1N11662QMB2
    19: 229R1N11682QMB2
    20: 229R1N11683QMB2
    21: 219RMM09538QMB1
    22: 219RMM09539QMB1
    23: 219RMM09540QMB1
    24: 272LBT01613NB5
    25: 272LBT01602NB5
    26: 272LBT01607NB5
    27: 153Q7P15591KB4
    28: 229R1N11669QMB2
    29: 229R1N11670QMB2
    30: 154H2A12265D
    31: 229R1N11672QMB2
    32: 229R1N11673QMB2
    33: 229R1N11668QMB2
    34: 229R1N11675QMB2
    35: 229R1N11671QMB2
    36: 229R1N11663QMB2
    37: 229R1N11681QMB2
    38: 229R1N11680QMB2
    39: 229R1N11679QMB2
    The car takes 34 cells, I bought 5 because I was measuring wrong and thought I had 5 bad cells, I was doing the whole thing wrong. Thank the electricity gods for rc chargers, makes life simple. #30 was a 2006 cell that was supposed to be 2014 or newer, #27 was the gen 3 cell. Luckily I did this today and was able to return both of them, what's odd is 24-26 are all the Amazon bought ones with, weird serial numbers, or maybe that's just me. But so far I have 2 extra cells, depending on how many of the cell batteries are bad/good.
    And here is my question: I have done 15 cycles for the two toast batteries #36 and #37 and they aren't that old... Is it possible and with what settings please can I revive them at? I've gotten them at 2700mAh but they don't seem to move at all.
    Is it okay to set the capacity limit high just to get a baseline or is that a big no, no?
  3. Kikto
    Kikto Junior Member
    Dover
    2002 Prius
    So, I got around to cleaning the HV fan I tried finding a way to take off the actual propeller, but no alas, there were a few hairs I couldn't get out but it spins freely and I wanted to test and see if it spins on its own, the battery never got anywhere near 90F and I tried forcing with Dr.Prius app and I don't remember seeing or hearing anything but I really don't remember. Problem is when I look this thing up I get a lot of 2 pin connectors, this one has 4, so I assume there's some sort of computer in there. I tried testing resistance too and nothing. Either the fan is shot, without me knowing 100% I will not know for sure. Anyone know the connector?
    Also, for anyone that cares, I've got a cell with 5mAhs for capacity. I also bought that one on Amazon so that'll be going back... EVHybrid is failing me but I got a guy that'll give me a 5500 capacity one for cheap. So that's good. Right now I got 9 at 7200 and a lot at 4000 - 5000 range, I might just pair them up good to bad and after I see if I can revive them let's hope.
    52,917
    well done!(y)
  5. Kikto
    Kikto Junior Member
    Dover
    2002 Prius
    I do not know how this happened... This one of the bad cells that has regained more than 8000mAh... The cut off is at 8000 this... This might take another couple weeks. So I can get the balancing right. I expected them to regain around 6000... Not this much.
  6. Kikto
    Kikto Junior Member
    Dover
    2002 Prius
    So, just an update, when I got the new imax B6 V2 it came with the ability to measure internal resistance. The cheap knock off Imax B6 is not helpful at all. I started using the other two (since they are the legit chargers) to check the knockoff, what I see is, the knock off says they reach to 8000 mAhs, stops charging. I think that's great they get up to 9.2v, now I thought it was good because it was sort of "injecting" a charge. When I re-cycled with either of the two legit chargers, it looks as if it does absolutely nothing to them. I will be returning the charger and getting a legit one. If anything when I cycle through they do get better, some take longer, others vastly improve. The resistances look wonderful, none too high, none too low. I'm going to recheck 3 because that is one of my top cells and it just doesn't seem right. Other than that I should of used a different method to note take my batteries. Seems like Excel is a wonderful and way better, organized option.
    1: 219RMM09519QMB1 C=8000 +CC R=158mohms
    2: 219RMM09520QMB1 C=8000 +CC R=134m
    3: 219RMM09521QMB1 C=7507 D=7884 R=261m
    4: 219RMM09522QMB1 C=6356 D=6465 C=6517 D=5579 R=139m
    5: 219RMM09523QMB1 C=4343 D=3451+ R= D=8000^ + C=8000
    6: 219RMM09524QMB1 C=4980 D=4740 +C=8000 R=169m
    7: 219RMM09525QMB1 C=8000 +C=2313 D=1682 R=153m
    8: 219RMM09526QMB1 C=8000 +C=4425 D=3706 R=144m
    9: 219RMM09527QMB1 C=8000 +C=3461 D=2314 R=153m
    10: 219RMM09528QMB1 C=8000 +C=4152 D=4152
    11: 219RMM09529QMB1 C=8000+ C=2616 D=1531 SDR=151
    12: 229R1N11660QMB2 C=8000+ C=2450 D=1512
    13: 229R1N11676QMB2 C=6037 D=5129 R=136m
    14: 229R1N11677QMB2 C=4349 D=3536 +C=5141 D=4098 R=148m
    15: 229R1N11678QMB2 C=6333 D=7062 R=172m
    16: 229R1N11661QMB2 C=8000 + R=156m
    17: 229R1N11674QMB2 C=8000 R=167m
    18: 229R1N11662QMB2 C=2595 D=1772 C=8000 R=147m
    19: 229R1N11682QMB2 C=8000 R=137m
    20: 229R1N11683QMB2 C=7788 D=6476 R=161m
    21: 219RMM09538QMB1 - R=158m
    22: 219RMM09539QMB1 C=8000+CC R=166m
    23: 219RMM09540QMB1 C=8000 R=144m
    24: 272LBT01613NB5 C=8000 R=150m+
    25: 272LBT01602NB5 C=8000 R=128m
    26: 272LBT01607NB5 C=8000 R=117m
    27: 153Q7P15591KB4 gone
    28: 229R1N11669QMB2 C=8000 R=135m
    29: 229R1N11670QMB2 C=8000 R=139m
    30: 154H2A12265D gone
    31: 229R1N11672QMB2 C=2113 D=1332 C=8000 R=118m
    32: 229R1N11673QMB2 C=8000 R=135m
    33: 229R1N11668QMB2 C=8000 R=144m
    34: 229R1N11675QMB2 C=8000 R=154m
    35: 229R1N11671QMB2 bad R=135m
    36: 229R1N11663QMB2 bad R=120m
    37: 229R1N11681QMB2 exploded 1/23/20
    38: 229R1N11680QMB2 okay R=138
    39: 229R1N11679QMB2 very good R=154m
