2014 Camry won't turn on, check hybrid system
Discussion in 'Toyota Hybrids and EVs' started by Priusprofit, Dec 28, 2018.
  1. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    All fuses good and 12v was disconnected for 5-20 minutes each time I made an attempt to start, the trip count did not reset though so I'm thinking maybe not long enough? I called it a night, its 3am here so it will sit disconnected while I get a few hours of sleep.
    51,944
    how many miles on this 2014 hybrid camry? clean title? any accidents or other we should know of?
  3. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    272k, clean title no accidents, used as a nyc taxi
    51,944
    ah, thank you
  5. egn83b
    egn83b Junior Member
    59
    Rarford nc
    Last thing to check is your remote battery on your key chain that the immobilizer works, beyound that you may just need to tow it to the dealer. If all else fails.
  6. JC91006
    16,769
    8,567
    Are all the nuts tightened on the bus bar? Not missing any?
    Raytheeagle likes this.
  7. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Yes and no
  8. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    The car goes into accessories so I assume that's fine.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    If everything isn’t right, that would explain the issues;).
    What nuts are missing:whistle:?
  10. egn83b
    59
    Rarford nc
    If it still showing codes it might be best to get it properly diagnosed by toyota the hybrid system could be inoperable tell its sorted out. The other avenue is check out diyalldata for info but thats not gonna net much because toyota hybrid car repair info is kinda kept under lock and key from public viewing from what i have seen trying to reasearch my prius.
  11. JC91006
    16,769
    8,567
    Check the little wires on the bus bar, you most likely broke one of the sense wires or temperature wires
  12. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    That's my next move
  13. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    So that day (about 2 weeks ago) I removed the battery and under close examination noticed one of the nuts were loose connecting one of the bus bars, so I tightened it.
    The car started, no codes, drove off and had no issues for approximately 300 miles
    Then code p0A80 comes up and car is relying more on gas and not performing, I figure as my last attempt that I check the battery fan to see if it could use a cleaning. I clear the code, remove and clean the fan, and now the car does not turn on again. There is no codes and it displays "check bybrid system".
    I beg of someone to either help me get this car running or get me far far away from it
  14. bisco
    51,944
    some have forgotten to reconnect everything at the fan
