2014 cannot jump start
Discussion in 'Gen 3 Prius Main Forum' started by Suspenderman, Mar 12, 2025.
  1. Suspenderman
    Suspenderman Junior Member
    Hayesville, NC
    2014 with dead auxillary battery and has sat for 2 months untouched. Now trying to jump start according to the directions through a tab in the engine fuse box with separate ground location but absolutely nothing. Is there a main fuse that could be the problem?
  2. JC91006
    16,939
    8,647
    You might not have a good connection with your jump start tools. Make sure the ground is good.
    You can check if your connection is good by turning on your headlights. If they are nice and bright, then it's probably a good connection
    Brian1954 likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Dead battery disconnected?
    The old one can suck all the energy out of the new one.
    Grit, Danno5060 and Brian1954 like this.
    52,927
    The tab only has metal on one side, so make sure you have a good connection
  5. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    Does anything else work? dash lights...
  6. Suspenderman
    Hayesville, NC
    No lights at all
  7. Suspenderman
    Hayesville, NC
    Good point. Took the terminals loose but probably was not totally disconnected. Thanks
  8. Suspenderman
    Hayesville, NC
    Thank you
