2014 front license plate kit part # ?
Discussion in 'Gen 3 Prius Main Forum' started by HoustonEvolution, Mar 12, 2018.
  1. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    Just bought my first Prius Two (2014) and love it so far. State of TX requires a front license plate so I'm looking for the OEM part number for that year front license plate base.
    I did a search on the forum here and found it to be super helpful. Unfortunately, I never saw WHERE to buy a new base kit or the stock part number I could search for. I'd rather not just drill into the bumper directly and it doesn't look like Amazon has much to offer. No offense but I'm not into the relocation kit (just not interested in anything THAT fancy.)
    Great forum so far. Thanks for any advice!
    I'm looking for whatever is "stock". I found this pic online to help. (I'm guessing that's stock.)
    Raytheeagle likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    Please verify first with Toyota Dealership Parts Dept., but I believe you are looking for Toyota p/n 52114-47130.
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I have a spare in the garage that I would part with:whistle:.
    PM me if interested (y).
    Prodigyplace likes this.
  5. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    Wow..... You guys are good!
    I have a few other replacement items needed but I'll do the due diligence & search a bit first. (Always hated it when people come in a forum & want a concierge.)
    Prodigyplace and Raytheeagle like this.
  6. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    Something kind of weird. So I bought a kit off ebay along with the hardware that you can use to mount it. It looks like you use the tapping screws in the large holes (which actually line up perfectly w/ the dimples in the bumper) to mount the base. BUT...then how would one mount the plate? there's nothing on the back side for the screws to grab on to. And of course if you were to mount the plate onto the base first, then you couldn't mount the base because the large holes would be covered by the license plate you just bolted onto it.
    I guess I could mount the base with the tapping screws first, then use the other tapping screws to attach the plate but in reality, those screws would go through the base (not really touching it) and then screw MORE holes into the bumper.
  7. Mendel Leisk
    42,362
    Yeah, there's a missing piece. I would say you need a metal clip with threaded hole, that pushes onto the inside edges, per this:
    And then the fine threaded screws go through your plate and screw into that clip. I'd try contacting the seller first, seem like they screwed up, pardon the pun.
    Some pics from mine, a bit different but same principle:
    Raytheeagle and HoustonEvolution like this.
  8. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    bingo! that's definitely the problem. dangit..... I'm gonna try to find those metal pieces. (likely easier than dealing w/ amazon)
    thanks for the info!
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    Since you already have a bracket, look at items 14 & 15 in this link. They apparently come with the Toyota bracket, Item 13
    2014 Toyota Prius Parts - metrotoyotapartsnow.com
