2014 Honda Accord Plug-in Hybrid preview
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ggood, Sep 5, 2012.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    2014 Honda Accord Plug-in Hybrid preview | The Car Tech blog - CNET Reviews
    See the 2014 Honda Accord Plug-in Hybrid (pictures) - CNET Reviews
    "The Accord Plug-in Hybrid has three drive modes, which activate automatically or can be chosen by the driver. With a full charge in the battery, the car will drive as an electric vehicle, although the engine may start up at high speeds or under heavy acceleration. The car's hybrid mode is more intriguing. Similar to the Chevrolet Volt, it uses the engine as a generator, creating electricity for the drive motor. The battery pack will also contribute, using electricity from the grid and whatever it can garner from the car's regenerative braking. In the Accord Plug-in Hybrid's third mode, the gas engine mechanically connects to the drive wheels, giving additional motive power to what the electric motor can supply."
  2. HyperFX
    HyperFX NIMFY (not in my front yard)
    81
    35
    30
    New Jersey
    Bravo. Honda and many manufacturers are going down the right path. Once again skeptics will critique this new vehicle but in the end, the main goal is to ween ourselves off oil dependency. Honda, welcome to the electric "Plug In" game.
    snead_c likes this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Quick thoughts: Sounds very close to the Volt concept. The HV button could be in a better spot. Trunk space looks smaller than my HyCam. 12V remains in traditional location. Nice package with two things missing: price and EPA estimates.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Wonder what the HV MPG is going to be. How much room will that 6.7 kWh PHV battery going to take up in the trunk?
    It is not clear if it is going to use traditional mechanical transmission or not.
  5. bisco
    52,875
    i have to wonder how many people at this level will want a plug in car?
  6. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    It is very close to the fusion energi. 6.7kwh battery versus 7.5kwh, both with 2 liter atkinson ices and mid 190s blended hp in a mid sized car.
    Here's the picture from the original link
    See the 2014 Honda Accord Plug-in Hybrid (pictures) image 7 - CNET Reviews
    old information but no traditional transmission, I'll let you glean from that what you can.
    Honda Accord Plug-In Hybrid Prototype Drive – Review – Car and Driver
    usbseawolf2000 and cwerdna like this.
  7. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    CR's car blog also has a write up:
    Getting a charge from driving the 2014 Honda Accord Plug-in Hybrid
    "According to Honda, the plug-in Accord operates as a fully electric vehicle (a series hybrid) up to highway speeds (about 50 to 60 mph). For the first 15 miles, as long as you stay below those speeds, the gasoline engine won't start. If the battery is depleted, the gas engine will run a generator to provide electricity. Above 45 mph, a clutch engages and connects a 137-hp, 2.0-liter, four-cylinder gas engine to the wheels mechanically through a single-speed overdrive gearbox, which is more efficient for highway cruising than electric power. If you accelerate moderately, the electric motor can provide some boost. If you accelerate hard at highway speeds, the car reverts to electric drive mode, with the engine acting as a generator. This delivers more power than either the battery or the gas engine alone can provide. The battery can't release enough energy quickly enough to take advantage of the electric motor's full output. So, the gas engine turns a generator to provide peak power to the motor. (The Fisker Karma works this way, too.)"
    Here's the exterior
    Here's the tiny trunk:
  8. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    Seems like a Volt with a smaller battery pack. I expect the Plugin Prius to have better gas-only milleage given the energy lost in the generator.
    But it's clearly a step in the right direction. I hope it will not be too expensive. :)
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I really like the Accord interior. It will be interesting when the price and full specs come out.
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    It doesn't sound like HV mode is going to be efficient. At lower speed (below 50-60mph), it'll operate on series mode with conversion loss. At higher speed, the ICE can engage mechanically (single speed) so it won't have the flexibility of HSD. It can't lower the ICE rpm at high speed downhills.
    It surely can't reach 41 MPG (that of Camry hybrid). It may be able to top the Volt's 37 MPG in hybrid mode.
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    It is much simpler than the Volt as it only has one clutch instead of 3. It should have two coolants since the PHV battery pack is active air cooled. Volt has 3 coolants with the active liquid cooling.
    I wouldn't be surprised if this Accord PHV weight less than the Volt.
  12. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Nice to see more options. Real question above all others is how much will this cost? Probably too much.
  13. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    i actually like crazy looks of plugin even if most dont... and interior is good... but trunk proves this is not a serious market car :-(
