2014 low beams stopped working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kemmis, Mar 20, 2018.
Tags:
  1. kemmis
    kemmis Junior Member
    Durham, NC
    Strangest things... got in my car this morning and neither headlight would turn on. I had to drive to work with my fog lamps on which was barely enough light to see anything. The high beams would turn on if I pulled the light lever back towards me, but not when I pushed the lever forward (which is how you normally turn your high beams on for them to stay on).
    I checked all the pertinent fuses and they look fine. The bulbs look fine too, but I suppose they could have both gone out at the same time. What's confusing to me is the behavior where the high beams work when I pull the lever back but not when I push it forward. That makes me think it's not the bulbs, but something else.
    Any ideas?
    Thanks!!
  2. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Makes me think it's the stalk switch failing...
