2014 MFD starts fine then gets lines
Discussion in 'Prius v Audio and Electronics' started by Matt98svt, Apr 2, 2025.
  1. Matt98svt
    Matt98svt Junior Member
    94
    South Carolina
    2015 Prius v wagon
    Just bought a 2014 V for my daughter. The MFD starts up perfectly fine showing the Toyota symbol when you turn the car on and all functions seem to work fine but after about 30 seconds it’s starts to get white lines until after a minute or two the screen has gone almost completely white with lines. Anything I can do before just replacing it?
  2. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    The 57011 head units and Harmon navigation/expansion boxes in the 2012-2014 v have shown a tendency for heat cycling to form solder cracks on the circuit boards rendering functionality and/or display intermittent or failed.
    We replaced a 2011 vintage 57011 and expansion box (no JBL) with a 2014 vintage set and so far, so good.
    If I had to do it over again, I would roll the dice with a circa 2015-2017 510057 replacement set, including expansion box and harnesses.
    Matt98svt and MAX2 like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,053
    6,924
    Texas Hill Country
    They don't cost much on ebay but be sure it comes with the bottom mounted expansion box. Replacing it is not hard either but you need the instructions.
    Instructions
    Start at Fig 2-5 through 2-11 and then jump to Fig 3-4.
    Matt98svt, MAX2 and Air_Boss like this.
  4. Matt98svt
    94
    South Carolina
    2015 Prius v wagon
  5. Matt98svt
    94
    South Carolina
    2015 Prius v wagon
    Thank you!
    Air_Boss likes this.
  6. Matt98svt
    94
    South Carolina
    2015 Prius v wagon
    Thank you!
