2014 model suddenly running rough
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Mar 13, 2023.
  1. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Its at 188k miles. Several thousand miles ago it was running rough. Had Cyl# 1 misfire, and the "shudder of death" on initial cold start of engine. I cleaned entire egr system, and then the engine ran like new again. The codes being set now are:
    #1 cyl misfire
    # 1 Cyl fuel/air mismatch
    #2 cyl misfire
    Coolant level doesnt appear to have dropped.
    The spark plugs and coils were all replaced at abt 150k. I replaced water pump and pcv valve when egr was cleaned also.
    Im thinking from the way its shudders so strongly at lower speeds while accelerating that #1 and #2 cyl are not firing at all! How should I proceed with troubleshooting?
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Leak-down test
    moto g power ?
    bisco, Mendel Leisk and Grit like this.
  3. KamiKKazi
    KamiKKazi Member
    92
    60
    OC
    I hate to say it but this is sounding like the beginning of a head gasket leak. Monitor you coolant it may probably start to go down more over time and then you will know for sure.
    Grit likes this.
  4. Mendel Leisk
    42,271
    If it’s running true to course: it’ll be head gasket failure at the adjoining wall between cylinders one and two. EGR cleaning should be done every 50k; late in the day as you have done can’t turn back the clock.
    leak down test to confirm, then replace head gasket, new head bolts to play it safe.
  5. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
  6. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Well, can someone give me an idea as to what a head gasket job should cost. Of course if its a Toyota stealership, I realize it will probably cost 2x an independent garage ;-).
  7. bisco
    52,784
    Around two grand
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I wonder why nobody has suggested inspecting the #1 and #2 plugs ?
    And inspecting the oil dipstick and inside of the filler cap for white "foam" ?
    The evidence is all circumstantial at this point but actual evidence, or lack of, should be fairly easy to find.
  9. bisco
    52,784
    Were the sparks oem from a dealer?
  10. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    By entire EGR system do you also mean the intake manifold EGR runners?
    I would check the spark plugs visually. If you bought your spark plugs off ebay, then that's it (the problem). Same with the coils probably, do you have your old ones? While checking your plugs you can swap coils around as a quick check, or if they aren't OEM or not from a trusted dealer then I'd just swap the old ones back (if they were working when you removed them).
  11. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Denso irridium I think.....its been a while. Yes, i confirmed ive got some steam coming out of tailpipe and drops of water.
    So I decided I and my son will do the head gasket replacement. I checked Autozone and there are many manufacturers of head gaskets to choose from. Felpro is one.....what is the best one to buy?
    AAV2014iv and bisco like this.
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,012
    6,901
    Texas Hill Country
    (yesterday at 8:28pm)
    Never does "apparently" lose coolant at first but the severe rattles are an early warning. Initially the leak only occurs overnight and the engine seals it up when started.
    ...because most of us have been there and done that....
    (today at 10 pm)
    Sorry for your loss... Felpro. Be careful when you check the head, piston height and block, too many have learned another lesson by the second or third time.
    #12 rjparker, Mar 14, 2023
  13. DPri
    DPri Junior Member
    40
    Earth
    50K? May I ask how did you come up with that number?
  14. DavidDavid
    DavidDavid Junior Member
    29
    Clean your intake manifold
  15. PTS
    PTS Member
    99
    49
    Austin, Texas
    2013 Prius v wagon
    He was eating magic mushrooms in his younger days and had a revelation. The Jehovah Witnesses did the same thing but their premonitions failed on many occasions.
  16. rjparker
    11,012
    6,901
    Texas Hill Country
    It is certainly not a Toyota recommended interval. However, it is a bit of a priuschat mantra. It's not an easy job and will cost almost $1000 if done at a dealer. So the reality is most EGR and intake cleanings are done DIY by chanting priuschat readers.
    A compromise position is to ignore it if your gen3 engine is not burning oil. However, if the engine is one of the excessive oil burners, oil will carbonize in the EGR cooler and the intake passages. In that case, 50k mile intake and EGR cleanings may be warranted.
    jerrymildred likes this.
  17. Mendel Leisk
    42,271
    Personal experience. 50k miles will see somewhere between light to moderate carbon build up.
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    IIRC, the shop I just retired from charges about $600 for an EGR service.
    After cleaning about a thousand of them (and removing and replacing dozens). I'd agree that 50k miles is way too soon unless it's an oil burner. I just cleaned one for a friend that had 147k on his 2010 and it just blew out with an air hose and then some pressure washing. It was used, but it didn't seem like it had been out of there before. (NO ONE replaces the nut from hell! :LOL:)
    taxidriver50005 and Mendel Leisk like this.
  19. Mendel Leisk
    42,271
    Ok, 100k for first, then 50k thereafter? That would sync with the miles component of engine coolant replacement schedule. Maybe do the plugs a little early while the wipers and cowl are off, for expedience?
  20. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Based on my experience last week. I would check the sparkplugs. I just found 4 new bad oem spark plugs.
    I would also check resistance of the coils.
    New doesn't meen good.
