2014 model suddenly running rough
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Mar 13, 2023.
  1. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Well, thanks for pointing out that Im not a "real mechanic". I have never claimed to be a bonafide professional auto mechanic. Far from it. If I was, I wouldn't be here on this forum asking questions
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Rather than putting up with certain people here, just click the "ingore" feature. Then you won't
    see them.... You're life will be better for it...
    #42 ASRDogman, Mar 17, 2023
  3. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    Assuming the engine is still running without a load (not common) perhaps the damper is damaged between the engine and transaxle. Caused by the head gasket misfires. We have heard of one or two failed dampers after excessive misfires. Damper repair requires pulling the engine. Normal head gasket misfires also cause severe metal to metal sounds that is the damper slipping as designed.
    #44 rjparker, Mar 17, 2023
  5. ChapmanF
    19,025
    In fact, misfiring from any cause will make the same noises and, if sustained long enough, damage the damper the same way.
  6. Mendel Leisk
    42,347
    There’s a black plastic panel at the junction of transaxle and engine, accessible from underside. I believe you can pry that off, check for damper spring remnants, and also rotate crankshaft (with an assistant), observe damper plate while rotating?
    jerrymildred likes this.
  7. ChapmanF
    19,025
    I'm not sure there's much you can observe of the damper plate, on the other side of the flywheel from what you can access through the little hand hole.
    But if any spring bits have fallen down to the bottom of the housing, you should be able to snag those with skinny fingers or a magnet.
  8. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    The spark plug concern can't be stressed enough. The market is flooded with counterfeit plugs. Lots of people say they'll seem ok up to 5k miles, then they self destruct.
    You really have to rely on dealerships and very trustworthy parts suppliers for spark plugs. Even the kids working the counter at your local parts store know how to make an extra $20 an hour. It's a big problem.
    Jim Caldwell likes this.
