2014 Plug-in Advanced Questions from new owner
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Darkhelmet, May 30, 2014.
  1. Darkhelmet
    Darkhelmet Junior Member
    SoCal
    2014 Prius Plug-in
    Bought a 2014 Blizzard Pearl PiP Advanced a few weeks ago and want to know if I have the newest version of Entune\Nav already installed?
    My Map version is 21-13-17 (2013-06-1)
    My Entune is 1.3.232356
    Like the car so far. Not crazy about the handling at 70+ MPH. Came with the yokohama Avid s33 tires. Thinking of adding the TRD RSB and Front Strut Brace.
    Any other suggestions to make the car less wobbly on the freeway?
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I think you'll be very happy with the addition of those two items
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Check your TP too... maybe a few additional PSI will stiffen up the handling, factory 32psi makes the tires pretty soft.
    Darkhelmet likes this.
  4. Alyn99
    Alyn99 Junior Member
    37
    2014 Prius Plug-in
    I have a new 2014 PIP Advanced with same tires. Handles great at 40, 50, 60, 70 and beyond so don't know what you're reacting to. I am running 44psi front and 42psi rear and that made a big difference. I do plan on adding the TRD rsb later but can't say I am 'disappointed' with the stock handling so far, in fact, it's much better than I thought it would be. That being said, it was crap at 35psi front, 33psi rear.
  5. Darkhelmet
    SoCal
    2014 Prius Plug-in
    Will check this today. Thanks.
