2014 Plug in Battery issues..
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jack520, Apr 8, 2019.
  1. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    My 2014 Prius Plug only takes a 2 KW charge when I recharge it and get only 6 miles of electric range on it.....
    Anyone else having this issues ?
    A normal charge should be around 3.5 KW ...
    It is still under warranty.
    Jack
  2. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Perhaps you mean kWh (energy). kW is a measure of power and 2 kW is actually the normal maximum power the Plug-in Prius can charge at.
    The Plug-in Prius has a 4.4 kWh battery, of which about >3 kWh is available when new.
    https://avt.inl.gov/sites/default/files/pdf/phev/batteryPrius8663.pdf
    If you are saying you only get 2 kWh accessible, you have >1/3 degradation.
    How are you measuring this?
    Consider reaching out to @jacktheripper at [email protected] who is developing the Dr. Prius App in another active thread in this subforum.
    #2 iplug, Apr 8, 2019
    52,858
    i don't have a meter, so not sure about charge. i get about 11 miles on flat 30 mph roads with few stops.
    try measuring ev distance under those circumstances, with hvac off, and report back
    52,858
    how many miles on her, btw?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Something's not right. When I traded in my 89k mile 2013 a month ago, it was getting 10-14 miles depending on weather and speed. I usually got 3.8 to a fraction over 4 kWh per mile. I can't remember how much it took to charge, but it was over three kW, I'm sure.
  6. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    6 miles is not good, unless your car has extremely high mileage. My 2014 with about 40K, still gets 11-12 miles.
  7. islandboy71
    islandboy71 New Member
    Lakewood, CA
    My 2014 has 68K miles and i still get 10-11 miles.
  8. bisco
    52,858
    :sleep:
  9. Civiceg94
    Civiceg94 Member
    60
    45
    Nyc
    My 2012 with 102k and counting is getting 12.5 to 13 miles per charge in warmer weather now after doing the fuse recall.
  10. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Hmmm... my 2014 has 147K KM, and I normally get between 16-18km (10-11.25mi) on a charge. Usually closer to 16km. My ChargePoint Home reports that it usually pushes about 2.6KWh of energy on a charge, I have NEVER seen >3KWhs on a charge.
    Based on what others have said, the change energy sounds low, though the range seems about normal?
    I did buy the car used (@ 2 years / 39k KM), and from what the trip meters indicated (one had never been reset, and was something like 8% EV usage), the previous owner did not charge very often.
  11. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    The car will usually get about 2.5 Kwh in most cases, from no ev available to full, this will usually get about 9-12 miles, driving slow 30 mph to 50 mph , no ac or heat will get you about 11 miles, at higher speed 62 mph you will get about 5-8 miles, in some cases where you are constantly going up hill you will get even less, make sure that you are testing the car in a flat road at about 30-50 mph.
