2014 Plugin - Can it hold 4 ft x 6 ft whiteboard inside ?
Discussion in 'Gen 3 Prius Main Forum' started by Jas5, Jan 8, 2020.
  1. Jas5
    Jas5 Junior Member
    CA
    2014 Prius Plug-in
    Hello experts,
    Is there enough room to carry couple of 4 ft by 6 ft whiteboards inside 2014 prius plugin ?
    Will i be able to see the side / rear mirrors with 4 ft by 6 ft whiteboards inside ?
    Does that leave room for a co passenger on front / back
    52,855
    i don't think there's 48" in any dimension except front to back
  3. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    I can’t remember exactly, but I was thinking you could get away with 4x5 if it was put in at an angle. I think to get 6’ both front seats would have to be all the way forward
    You can do 2x8 if you fold the right side seats down (including the front seat leaning back) and the end goes into the passenger footwell, but it’s tight and potential to scratch up the interior.
    I purchased lumber once and hated the fear of scratching stuff up so I just plan accordingly and take the other vehicle
    -Spiral
  4. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    No it won't fit, maximum width is about 36" tight fit about 40" but you will probably scratch the car, maximum lenght with back seats folded about 5 ft, if you put all seats to the front maybe you can do a few more inches, i would not recomend doing this.
  5. ETC(SS)
    7,555
    No and No.
    You’ll have to get a larger vehicle or carry it “mattress-style” strapped to the top.
    I do not recommend this, especially if there is something important written on the whiteboard or you have low liability limits.
    Good Luck!
  6. Zeus661
    Zeus661 Junior Member
    36
    Hang on, I'll go buy one and see if it fits in mine
  7. bisco
    52,855
    cut it in half and glue it back together?
  8. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    I've fit an eight foot poker table in the pri.
    I've also fit entertainment centers, including the box, in the pri. I made bets with Best Buy folks that it would, indeed, fit inside. They are always impressed that a Prius can haul large items. Many pictures, speechlessness and jaw drops ensue once the hatch closes with my precious cargo inside.
  9. bisco
    52,855
    i got a refrigerator in there, but it wasn't 4x6
  10. spudnut
    spudnut Active Member
    145
    159
    Idaho Falls/Pocatello, ID
    I have carried numerous 10' long items, having the passenger seat out helps. I sold a lot of 300 watt solar panels (free delivery!) and as I recall, my '13 PIP has about 40" between the wheel wells. Don't think 48 wide is going to happen.
