2014 Prius 12V battery suddenly dead, then working after 1 hour
Discussion in 'Gen 3 Prius Technical Discussion' started by SKyu, Aug 18, 2023.
  1. SKyu
    SKyu New Member
    Atlanta, GA
    My prius died while I was in a store for 30 min, then it magically came back on. It still has the original 12V battery. I had the battery tested at Autozone and was told it is fine but needs a charge. Can I trust this battery or should I replace with new one?
    Today, my prius was driving normally. I parked at the store and came back 30 min later and the car wouldn't turn on. Dim, or flickering dashboard lights. I called a tow truck and waited for about 40 min. I went to get something from the car and the darn thing was on! I was able to drive home but worried it would randomly die again.
    Has anyone had a similar issue? Any advice would be appreciated.
  2. JC91006
    16,670
    8,516
    If you have the original 2014 battery, that's 9 years old. it's time to replace it, no matter what autozone says
    Brian1954, SKyu and ASRDogman like this.
  3. ASRDogman
    ASRDogman Senior Member
    7,186
    3,762
    The auto parts stores do not understand how the battery works in a Prius.
    It's an AGM battery, and is different from a lead acid battery.
    But even a lead acid battery will "come back to life" on and off when it's on it's last leg.
    Don't forget to charge the battery before installing it for at least 4-6 hours at no more than 4 amps.
    The car will not charge is enough unless you'll be driving for several hours.
    SKyu likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    9,565
    5,872
    Texas Hill Country
    Buy a new battery or it will do it again. The Prius does not need much 12v capacity to start but yours is on life support.
    Doug McC, Brian1954 and SKyu like this.
  5. SKyu
    SKyu New Member
    Atlanta, GA
    That's what I thought. Thank you all for your quick responses!
  6. bisco
    51,087
    and make sure the connections are clean and tight, especially neg to ground
    Grit likes this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Yes. Many.
    Get a new battery.
    You can't trust one that is 8 years old no matter what the (inept) test says.
    Doug McC likes this.
  8. Grit
    Grit Senior Member
    6,438
    4,184
    Wilkes Land
    Post no 6 is the first thing to do. Start troubleshooting the non cost stuff first.
